Tip & How-To about Samsung Omnia 7 (8 GB) Smartphone
How To Reset Your Samsung Omnia 7 or Omnia
Soft Reset
  1. Turn the power off.
  2. Remove and reinsert the battery.
  3. Turn the power on.
Hard Reset
This will erase all data and settings from the Omnia 7 device.
  1. From the Start screen, tap the arrow in the upper-right part of the screen.
  2. Tap Settings.
  3. Tap About.
  4. Tap Reset your phone.
  5. Select Yes two times.
  6. The Omnia 7 will now complete the factory reset.
This will erase all data and settings from the Omnia device.
  1. Press and hold the Send and the End buttons.
  2. Continue to hold down the buttons while using the stylus to press and release the small reset button on the top of the phone.
  3. Still hold the buttons until the Format screen is displayed. Press Send to choose Format.
Samsung Omnia 7 (8 GB) Smartphone Logo
lg g4 reset
To perform a master reset:
1. Back up all data on the internal memory
2. Turn off the device
3. Press and hold the Power and Volume Down buttons until the LG logo appears on screen
4. Quickly release and the resold the power button while continuing to hold the volume down button.
5. Factory data reset appears
6. Use volume down to highlight yes
7. Press power to confirm
8. Volume down again to highlight yes to erase all user data and restore default settings
9. Press power button to reset device
May 14, 2016 | LG G4
Can you fix my low on memory palm centro. It erased all of my photos and won't take new ones. It says momory is too low. Can you fix?
hi,
you have to reset your phone in order to fix that..but you have to save all your important data before you do the reset...here is how..
Performing a soft reset is similar to restarting a computer. If your Centro device is not responding or you're having trouble synchronizing with your computer, a soft reset may
help. All your information is retained when you perform a soft reset.
1. Remove the battery from your device, and then reinsert it.
Note: The reset begins when you insert the battery and ends when the
Date & Time Preferences screen appears.
2. Select Done.
Replacing the Battery
Your Centro device comes with a replaceable battery. Be sure to use a battery that is approved by Sprint and that is compatible with your device. Failure to use the proper
battery may result in personal injury or product damage, and it voids your device warranty.
1. Press Power/End palm_centro_hard_reset_soft_reset_2.jpg to turn off the screen.
2. Gently press down on the Battery Door, and then slide the door downward to remove it from your device.
3. Place a finger in the notch next to the battery and lift the battery up at a 45-degree angle to remove it from the compartment.
4. Align the metal contacts on the new battery with the contacts inside the battery compartment.
5. Insert the new battery into the compartment at a 45-degree angle, pressing it into place. Slide the battery door onto the back of the device until it clicks into place.
6. Connect your device to the charger or sync cable.
7. Wait for your device to turn on, and then enable the network time or set the date and time when prompted.
System Reset
A system reset, also called a safe or warm reset, can be useful if your device loops or freezes during a soft reset. Performing a system reset allows you to get out of the loop and restores limited functionality to your device in order to uninstall a third-party application that's causing the problem. Note that after a system reset, you must perform a soft reset to restore full functionality, including the wireless features, to your device.
1. Remove the battery from your device.
2. Press and hold Up palm_centro_hard_reset_soft_reset_3.jpg on the 5-way palm_centro_hard_reset_soft_reset_4.jpg while reinserting the battery.
3. When Date & Time Preferences appears, release Up palm_centro_hard_reset_soft_reset_3.jpg
4. Delete the third-party application that you suspect is causing the problem.
5. Perform a soft reset. (The wireless features of your device are not available until you complete this step.)
ard Reset
A hard reset erases all information and third-party software on your Centro device. Never perform a hard reset without first trying a soft reset and a system reset. You can restore previously synchronized information the next time you synchronize.
A hard reset can tell you if a problem stems from your Centro device or from an application installed on it. If you do not experience the problem after you perform a hard reset, the problem is related to software you installed.
Important: If you set a password on your device, performing a hard reset reformats your device (the message "Reformatting in progress" is displayed). This is a more severe form of a hard reset, which removes all your information and restores your formats, preferences, and other settings to the factory default settings.
Note: Some third-party applications do not create a backup on your computer when you synchronize. If you perform a hard reset, you may lose data in these applications and you need to reinstall these applications after the hard reset. Please contact the developer to find out which information is backed up during synchronization.
i hope it will help you..thanks for trusting fixya
Jan 31, 2011 | AT&T Palm Centro Cell Phone - White
I have an black one and everytime I turn it on its asking for an password and I don't know it
Hello guccimane04,
A hard reset will unlock the Palm Centro But it will ERASE ALL of your data. If you choose to do a hard reset, the following procedure will work:
• Remove the battery cover on the back of the Palm Centro
• Remove the battery for a few minutes
• Press the power button when Reinserting the battery
• Release the power button after the Palm logo displays on the screen
* The hard reset erases all your data ! (Run a hotsync to retore the data) *
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 20, 2010 | AT&T Palm Centro Cell Phone - White
2,900 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
