Tip & How-To about Samsung Vibrant
How To Reset Your Samsung Vibrant
Soft Reset
  1. Turn the power off.
  2. Remove and reinsert the battery.
  3. Turn the power on.
Hard Reset
A hard reset will reset all of the settings and data. The phone will return to factory default settings without affecting the data on the SD card.
  2. Press and hold down the Volume Down, Volume Up and Power buttons simultaneously.
  3. When the Samsung Vibrant logo appears on the screen, release the buttons.
  4. Press the Volume Down button to select Delete all data.
  5. Press Power.
Samsung Vibrant Logo
how do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
Can you fix my low on memory palm centro. It erased all of my photos and won't take new ones. It says momory is too low. Can you fix?
hi,
you have to reset your phone in order to fix that..but you have to save all your important data before you do the reset...here is how..
Performing a soft reset is similar to restarting a computer. If your Centro device is not responding or you're having trouble synchronizing with your computer, a soft reset may
help. All your information is retained when you perform a soft reset.
1. Remove the battery from your device, and then reinsert it.
Note: The reset begins when you insert the battery and ends when the
Date & Time Preferences screen appears.
2. Select Done.
Replacing the Battery
Your Centro device comes with a replaceable battery. Be sure to use a battery that is approved by Sprint and that is compatible with your device. Failure to use the proper
battery may result in personal injury or product damage, and it voids your device warranty.
1. Press Power/End palm_centro_hard_reset_soft_reset_2.jpg to turn off the screen.
2. Gently press down on the Battery Door, and then slide the door downward to remove it from your device.
3. Place a finger in the notch next to the battery and lift the battery up at a 45-degree angle to remove it from the compartment.
4. Align the metal contacts on the new battery with the contacts inside the battery compartment.
5. Insert the new battery into the compartment at a 45-degree angle, pressing it into place. Slide the battery door onto the back of the device until it clicks into place.
6. Connect your device to the charger or sync cable.
7. Wait for your device to turn on, and then enable the network time or set the date and time when prompted.
System Reset
A system reset, also called a safe or warm reset, can be useful if your device loops or freezes during a soft reset. Performing a system reset allows you to get out of the loop and restores limited functionality to your device in order to uninstall a third-party application that's causing the problem. Note that after a system reset, you must perform a soft reset to restore full functionality, including the wireless features, to your device.
1. Remove the battery from your device.
2. Press and hold Up palm_centro_hard_reset_soft_reset_3.jpg on the 5-way palm_centro_hard_reset_soft_reset_4.jpg while reinserting the battery.
3. When Date & Time Preferences appears, release Up palm_centro_hard_reset_soft_reset_3.jpg
4. Delete the third-party application that you suspect is causing the problem.
5. Perform a soft reset. (The wireless features of your device are not available until you complete this step.)
ard Reset
A hard reset erases all information and third-party software on your Centro device. Never perform a hard reset without first trying a soft reset and a system reset. You can restore previously synchronized information the next time you synchronize.
A hard reset can tell you if a problem stems from your Centro device or from an application installed on it. If you do not experience the problem after you perform a hard reset, the problem is related to software you installed.
Important: If you set a password on your device, performing a hard reset reformats your device (the message "Reformatting in progress" is displayed). This is a more severe form of a hard reset, which removes all your information and restores your formats, preferences, and other settings to the factory default settings.
Note: Some third-party applications do not create a backup on your computer when you synchronize. If you perform a hard reset, you may lose data in these applications and you need to reinstall these applications after the hard reset. Please contact the developer to find out which information is backed up during synchronization.
i hope it will help you..thanks for trusting fixya
Jan 31, 2011 | AT&T Palm Centro Cell Phone - White
network failure
Call customer service from your service provider.
AT&T Customer Service 1-800-288-2747
You can also try a soft reset on your phone with the phone ON remove the battery wait 5 seconds put the battery back in the phone and turn it back on. Or you can do a wipe/hard reset
Samsung GT-i9000 Galaxy S hard reset
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 master reset
Aug 16, 2010 | Samsung Galaxy S GTI9000 Smartphone
Iwant to hard reset this phone
A reset of a BlackBerry smartphone does not delete any settings or data.There are two options for performing a reset: a hard reset and a soft reset. A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry
smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
May 04, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
2,409 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
