Tip & How-To about Cell Phones
How To Reset Your Blackberry Smartphone
Soft Reset
  1. Press and hold the Alt key.
  2. While holding down the Alt key, press and hold the Right Shift key.
  3. With both of those buttons still pressed, press the Backspace/Delete key.
  4. The display turns off to indicate that the reset has started, and the keys can now be released.
Hard Reset
  1. Remove the battery cover.
  2. Remove the battery, and then reinsert it after a few seconds.
  3. Replace the battery cover.
Factory Reset
The following will delete all data and applications on the BlackBerry smartphone. Back up the data on the BlackBerry smartphone before proceeding. The process for deleting all data and applications can take up to an hour to complete. Do not remove the battery while data is being deleted.
Note: To identify the version of BlackBerry Device Software on your BlackBerry smartphone, go to Options > About
BlackBerry Device Software 2.6
Note: If a password is already set, go to step 5.
  1. From the Home screen of the BlackBerry smartphone, click Options. The Device Options screen is displayed.
  2. Click Security. The Security screen is displayed.
  3. In the Password field, press the Space key to enable the password. A dialog box will prompt for a password with at least four characters.
  4. Type a password. Click the trackwheel. Type your password again to verify it.
  5. On the Home screen, click the Lock icon. The Lock screen is displayed.
  6. Type your password incorrectly 10 times to trigger a security wipe.
BlackBerry Device Software 2.7
  3. Click the trackwheel, and select the Wipe Handheld option.
BlackBerry Device Software 4.0
BlackBerry Device Software 4.1 to 4.2.1
  1. From the Home screen of the BlackBerry smartphone, click Options > Security Options > General Settings.
  2. Display the menu and select the Wipe Handheld option.
  3. Click Continue.
  4. Type blackberry, and then press the Enter key.
BlackBerry Device Software 4.2.2 to 4.7
  2. Press the Menu key, and select the Wipe Handheld option.
  3. Select the Include third-party applications check box to remove third-party applications. Clear the check box to preserve third-party applications.
  4. Click Continue.
  5. Type blackberry, and press the Enter key.
BlackBerry Device Software 5.0
  1. From the Home screen of the BlackBerry smartphone, click Options > Security Options > Security Wipe.
  2. Select the appropriate check boxes to remove data and applications as intended.
  3. Type blackberry, and click Wipe.
BlackBerry Device Software 6.0
  1. From the Home screen of the BlackBerry smartphone, click Options > Security > Security Wipe.
  3. Type blackberry, and click Wipe Data.
To reset a legacy BlackBerry device (Research In Motion® (RIM®) 850, 857, 950, 957 devices), insert the end of a paper clip into the small hole on the back of the device.
Cell Phones Logo
my blackberry 8520 has a white screen saying app error 523
Perform a hard reset by removing the battery from the smartphone andreinserting it. For more information on this procedure, see KB02141.
A reset of a BlackBerry smartphone is a troubleshooting method thatcompletely turns off and restarts the BlackBerry smartphone's operatingsystem software and applications. It is a useful first step if aBlackBerry smartphone is experiencing hardware, software, or wirelessnetwork problems.
Note: A reset of a BlackBerry smartphone does not delete any settings or data.
There are two options for performing a reset: a hard reset and a soft reset.
A hard reset involves physically removing thebattery from the BlackBerry smartphone and then reinserting it. Toperform a hard reset, complete the following steps:
  1. Remove the battery cover from the back of the BlackBerry smartphone.
A soft reset is a three-key combination that resetsthe BlackBerry smartphone without removing the battery. It is onlyavailable on BlackBerry smartphone models with a QWERTY keyboard. Donot attempt to perform a soft reset on BlackBerry smartphones that areequipped with SureType® technology or the SurePress™ touch screen, suchas the BlackBerry® Pearl™ Series, BlackBerry® Pearl™ Flip Series, andBlackBerry® Storm™ smartphone.
To perform a soft reset, complete the following steps:
  1. Press and hold the Alt key on the BlackBerry smartphone.
  3. With both of those buttons still pressed, press the Backspace/Deletekey. The display on the BlackBerry smartphone turns off to indicatethat the reset has started, and the keys can now be released.
Note: Some BlackBerry smartphones do not displaythe Alt, Right Shift, and Backspace/Delete keys in the same manner.However, the location of the keys does not change. Refer to thefollowing graphic for key position
If the error message persists, perform a reload or upgrade theBlackBerry Device Software. For more information on this procedure visit http://us.blackberry.com/support/downloads/
Apr 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
blackberry freezes and doesnt recieve all messages
Try this steps to perform soft reset
1)Press and hold down the ALT key on the smartphone.
2) While holding down the ALT key, press and hold down the right-hand CAP key.
3) With both of those buttons still pressed, press the DELETE key. The display on the BlackBerry smartphone will turn off to indicate that the reset has started, and the keys can now be released
Still if you face same issue Download and install the latest BlackBerry Device Software, which is available from the BlackBerry.com
Hope this is helpfull for you
Nov 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
how do i do a master reset
A Hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:-
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
To perform a soft reset, complete the following steps:-
1) Press and hold down the ALT key on the smartphone.
3) With both of those buttons still pressed, press the DELETE key. The display on the BlackBerry smartphone will turn off to indicate that the reset has started, and the keys can now be released.
Nov 08, 2009 | RIM BlackBerry Storm 9530 Smartphone
353 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
