Tip & How-To about Samsung Galaxy S GTI9000 Smartphone
How To Reset Your Samsung Galaxy
Soft Reset
  1. Turn the power off if you can.
  2. Pull the battery out and reinsert it.
  3. Turn the power on.
Hard Reset
This deletes all data on your phone including downloaded applications and settings, application data, system and accounts. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. From the main home screen, tap Menu.
  2. Tap Settings, then Privacy.
  3. Tap Factory data reset.
  4. Tap Reset phone.
  5. Enter your password, then tap Yes to confirm.
or
  1. Turn the power off or pull the battery out and reinsert it.
  2. Hold the Volume Down button (Some models will may use the Volume Up button instead)
  3. Press and release the Power button.
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock.
  5. Select Clear Storage by pressing the Volume Down button.
  6. Press and release the Power button.
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO.
Samsung Galaxy S GTI9000 Smartphone Logo
how do I do a factory restore on a Coolpad 3300A
http://www.hard-reset.com/coolpad-quattro-4g-hard-reset.html
Coolpad Quattro Hard Reset (Factory Reset)
    1.Turn off your Coolpad Quattro phone and pull out battery and reinsert it after a few seconds
    2.Press and hold both Volume DOWN + UP and hit POWER button until "Recovery mode..." showing on the screen. When the triangle with an exclamation mark appears touch the HOME touch key to enter Recovery menu.
    3.Select Factory reset/ wipe data. (scroll down with VOL down.)
    4.Select with power.
    5.Scroll down to Yes - delete all user data. Press power to confirm. If your phone is responding to screen input, then open Settings from the Applications menu. Tap Backup & reset > Factory data reset; click Reset phone and Erase everything to format your phone.
Jan 04, 2016 | Computers & Internet
how do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
Phone does not go past start up screen. Can you help
You may perform a Soft REset
press volume up key and power button together for 5 secs. It will turn off and on automatically.
if that does not work you may do a hard reset (which will erase all data)
First, try this:
  1. From the main home screen, tap menu
  4. Tap Reset phone
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Mar 22, 2011 | Samsung Galaxy S GTI9000 Smartphone
my bb is getting rebooting
If your BlackBerry Bold 9000 series device is frozen, rebooting or not responding, you will probably want to reset the unit. Here are the different types of resets that can be performed in the order they should be tried.
Remember your data will we wiped. So make a backup.
Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE.
Double-Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE . The screen will go blank for a few seconds. When the screen comes back on, immediately press ALT + RIGHT SHIFT(CAP) + DELETE again.
Hard Reset
If none of the above works, pull the battery out of the unit for a few seconds, then reinsert it.
Mar 12, 2011 | RIM BlackBerry Bold 9000 Smartphone
4,820 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
