Tip & How-To about HTC Hero Smartphone
How To Reset Your HTC Hero
Soft Reset
  1. Turn off the phone, if you can.
  2. Remove the battery and wait 1 minute.
  3. Reinstall battery and turn on the phone.
Hard Reset/Factory Reset
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state.
  1. Press HOME > MENU, and then tap Settings > Security > Factory data reset.
  2. On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
  3. Your phone will erase all personal data and restart. It may take a few minutes for the process to complete.
or
  1. When the phone is turned off, press and hold the HOME, END CALL/POWER, and BACK buttons.
  2. The reset process will start after a few seconds.
  3. When the phone finishes the reset process, press MENU.
Click here for other Tips and Tricks for the HTC Hero.
HTC Hero Smartphone Logo
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
Vibration mode is not working on vibrate Mode as well as Sound Mode on my Samsung GT I8262
hear try or reset all if well done f we not ur hardware of cp is problem
How to Soft Reset or Reboot or Restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
There are several ways to do soft reset or restart, the easy way to soft reset or reboot or restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL by remove the battery and then put again to the place then turn on the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL. If you do not want to open the battery, you can do easily with pressing Power Button for several seconds and the option menu to turn off or reboot will appear.
#Option 1, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with software menu:
  1. Turn on SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  2. Make sure SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL battery is not empty
  3. Go to menu: Setting > Backup and reset > Factory Data Reset > Reset Device
  4. Choose Erase Everything
  5. SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will do the process to Master Reset to Factory Default, wait for several minutes.
#Option 2, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Hardware key button:
  1. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL charge properly
  2. Turn off SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  3. Press and hold together : Volume Up Button + Home Button & continue with Power Button (together)
  4. If we see the menu at LCD screen, choose Wipe Data/Factory Reset with Volume Button to select and use Power Button to ok or enter.
  5. The SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will doing the process of restoring to factory default.
#Option 3, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Secret Key Code Security:
  2. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL not empty
  3. dial or press number to call: *2767*3855#
  4. That number code will force format SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
How to Restore and Reinstall Clean Android Operating system / firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
Do not worry to do reinstall or restore the clean and default setting Android operating system or firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL because the file source already saved inside the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ROM. If we think the phone really need to be reinstall or restore the default Android operating system or firmware, then we can do it easily by doing hard reset or master format step above, because the operating system will be reinstall by itself.
goodluck sir.
Jul 04, 2014 | Samsung Cell Phones
Hi I have a problem with my phone i-mate jaq. the problem is that I blocked, and now I can not remember the password. help me please. thanks
You need to reset your device to factory installed settings, to use your cellphone, there are two type of reset you can apply, 1. Soft reset 2. Hard Reset
1. To perform a soft reset
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
2. To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
Caution, Hard reset will delete all your data from the Phone memory, including contacts, messages, or pictures you have in phone memory
If you require more assistance, feel free to reply to this post
Regards-BA
Jan 14, 2011 | i-mate JAQ Pocket PC
1,947 people viewed this tip
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
