Tip & How-To about Computers & Internet
Restoring to Factory Settings
A very common issue with most people is what to do when your computer crashes and will no longer boot up. I wish to start by saying save any discs or software that came with your machine it is imperative that keeping these discs will assist you in the future in case this issues do arrive. Second prepare you computer with doing a system backup. So that you have any valuable information on a disc or USB device or any external method outside of your computers hard drive. What I do "TIP" I have a backup drive on my computer. Any and all pictures, movies, special files are stored on my backup drive and not my C:\Drive. All software files downloads anything that I can retrieve to reinstall due to a C: drive crash can be brought over from my backup drive in an instant. This is the easiest way to keep your files safe. Investing in one is cheap and easy to install. Even if it is a external drive it is well worth the investment.
The BIOS is your main source of access. You can set time you can set boot order you can boot up from your BIOS learn how to get into your BIOS most new users do not even know you can do this. This is the main resource for restoring software and doing a recovery process on some computers. The issues that arise are lost passwords and usernames as well as boot orders being set to Hard Drive Booting First when the default setting on computers these days are boot from CD or DVD. So if you cannot boot from your recovery disc this is the main problem this is where you will have to learn how to set the boot order if it is not defaulted to CD or DVD as the first boot. If this is set you can boot from any CD or DVD disc to install an Operating System back on to your machine. Usually F2 or the delete key will get you into your BIOS. If all is lost set the BIOS setting to default settings hit esc then save. This will set your BIOS to default settings.
Recovery DVD or CD's can be purchased from you manufacturer or offered in a downloadable file when you purchase your computer. It is a good idea to purchase your software legally. So that you have the right keys and you own it otherwise you will run into issues with "WGA" Windows Genuine Activation. It can be a pain to pass even for those that own their software. People do hack cracks that bypass WGA Microsoft is constantly working diligently to catch people that are pirating and taking the software illegally. So to avoid this problem purchase a legal copy of Windows.
Use manufacturers DVD or recovery discs only on your computer if you are not familiar with installing a new software Operating System on a computer. "WHY" drivers and other computer devices may not update and a you have seen with some of the questions. Drivers are always needed. With a factory boot recovery disc for your computer drivers come with the software. So it makes installing and recovering much easier to deal with.
In closing there is not much to doing a recovery on a crashed machine. Insert the recovery CD or DVD and boot from DVD or CD as the first boot and away you go that is about it. You can also perform a repair it is one of the options included with the install. You can always go back to an earlier time when you new you did not have a problem. Be sure to set your computer to back up files. Thanks for using FixYa! John
Computers & Internet Logo
How can I identify the update that causes the crashing and freezing in windows 8.1?
Try going to Control Panel, and then uninstall programs. You should have an option to see recently installed updates. Find your most recent updates, the ones that date when your computer crashed, and then uninstall them. Then instead of doing an automatic install actually view you're updates, and install them manually, One at a time. If you can't even get your computer to start up, you might try putting in your CD of Windows 8.1, or if you don't have that, your reboot disc, and have your computer boot from disc instead of boot from drive. To do that you would have to go into your bios by pressing F2, F5, or F8 right after you start your computer up, and that should take you into your bios, at which point you change your boot settings. Save your save your changes, and then keep trying to boot your computer back up. If you don't have a boot disk, you're going to have to take it to someone who does, like at Best Buy or another computer repair company.
Nov 14, 2014 | Toshiba Satellite C55D-A5201 AMD Dual-Core...
can i repair a problem on my 3000 dimension computer without the disc my computer crashed
Yes normally you can
When you say computer crashed, when you restart it what happens? Does windows start?
Usually you can go to control panel and create a new disc if you lost it.
Or there will be a seperate partition on your hard drive that has the contents of the restore disc.
When the PC boots up at start it should say something like Hit F10 or similar key to restore?
Hope this helps
Apr 07, 2011 | Dell Dimension 3000 PC Desktop
Computer crashed and says "Missing NTLDR." I have
Hello, before you do anything drastic, my computer crashed and on reboot said the same thing. After panicking (and a cup of tea), I found the bios had defaulted to booting from the wrong disk. All was ok after I set the bios back to boot from the correct disk again.
Hope this helps!
best wishes,
nicam49
Dec 29, 2010 | Toshiba Satellite M35X-S149 Notebook
The screen on "Compaq Presario SR1103WM-B PC Desktop" says the DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. I DNT KNO WAT TO DO PLEASE HELP?
Hello 8323888916,
There are a few things that can cause this problem. Lets go through a few things to help narrow it down and possibly solve the problem.
  1. Check to make sure there are no CD's, USB drives or Floppy discs in your computer.
  2. Check to make sure your hard drive is listed and set to be the first boot device in your BIOS. You can do this usually by holding down F2 when your computer starts. Then finding the "Boot Options" or "Boot Device Order" menu. Make sure there is a hard drive listed, usually will say something like PATA, SATA, IDE and set that hard drive to the first position in the boot order list, save and exit.
  3. If this does not fix the issue you can try to do a "Repair Installation" of windows using a Windows Installation disc (not the restore discs that come bundled with a computer). This procedure will reinstall important Windows system files that can become corrupted and cause these kind of problems to happen. Note: this will be the second repair option from the windows disc you do not want to choose to enter the "Recovery Console" these two tend to get confused for one another sometimes.
  4. If that doesn't work you may need to replace your computer's hard drive as it may have failed in some way.
Hope this helps, good luck. Don't forget to leave a positive note if you found this to be helpful. Thanks!
Feb 18, 2010 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
computer crashed, won't go to windows
When you start you computer, after the bios flash. press the F8 on your keyboard before the Windows start loading. You should have an option to select to go to safe mode.
Select the safe mode option only. See if it will load the Windows under the safe mode option. If it did load the Windows under safe mode. There is an issue loading the driver of your Windows O.S. that i why its not booting under the Normal mode. Sometimes this is cause also by a Virus on your computer. You can run the Anti-Virus program under Safe mode to check for viruses
To fix this you may need the Original Disc of Windows O.S.
You can reboot the computer. Load the disc make sure that under the Bios option the CD drive is the first boot. Then save it.
after rebooting. Follow the on screen instruction on how to repair the O.S. There should be an option to repair the O.S. when you boot the computer using the Windows O.S. Disc
Note:
If you could do a backup of your files, do it first before repairing the O.S.
If it will not resolve the issue, you will have to reformat your computer.
Sep 09, 2008 | Computers & Internet
184 people viewed this tip
David Payne
David Payne
