Tip & How-To about Cameras
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.
We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.
If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
Cameras Logo
No memory card error
You need to change the memory card with new one, because memory card got corrupted and needs replacement.
Thanks
Feb 24, 2012 | Canon PowerShot SD1000 Digital Camera
I am getting a "Memory
Its a very common problem with S400,S410 and some others.
As a case study, see the following error message on the Canon IXUS 130 when trying to view some photos previously stored in the memory card SDHC
"Memory Card Error"
Every single photo stored on the memory card becomes inaccessible after the above error message. In addition, no more photos can be stored on the memory card. In short, the card can not be read or written.
Cause:
The above error message that makes all the pictures inaccessible is mainly caused due to corruption of the memory card. Reasons why you are responsible for the above error message is virus infection, interrupted read / write operation, and human error.
Resolution:
The resolution for the above error message is the format of memory card into the camera. The process erases all data previously stored and allows you to save the new data. While the format is a good resolution for users who do not require the old data, it is fatal to users such as photographers, detective agencies, etc, to save critical data on your memory card. However, the formatted data recovery day is now an easy process. It is therefore necessary to use an advanced part of third parties. A tool for image recovery is readily available on the Internet by one click.
Data Recovery is an application of high-end recovery that recovers data from almost all formats SDHC Card, XD and MMC. The read-only photo recovery tool also allows you to restore data in the defined location. The software runs on Mac OS X and Windows.
Check this link for additional details: Simple Fixes for SD "Memory Card Locked" or "Memory Card Error"
Hope helps.
Jun 07, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
I have a finepix S602Z and when i turn it on it comes up as card error this happens on different cards any ideas on how to correct this please
I suggest you take the batteries out and wait two minutes and reinsert them. Making sure that they are inserted correctly. If this doesn't work, try replacing the batteries with new ones.
If you formatted the memory card using your computer, or deleted images using your computer, you now need to Format the card with the CAMERA. One of the camera menus will have a Format command.
This is what FujiFilmUSA.com has to say about the Card Error:
Feb 14, 2011 | Fuji FinePix S602 Zoom Digital Camera
when turn on the camera 'Card Not Initialized" appears !!??
This message can be caused by several things, including; incorrect memory card, incorrect memory card insertion, dirty points of contact, settings on the camera are in error.
Teleplan Camera Repair offers Fuji Camera Repair and will take care of it! http://www.teleplancamerarepair.com/Fujifilm_FinePix_S3000
Immediate online quote and affordable repairs by expert techs.
Oct 04, 2010 | Fuji FinePix S3000 Digital Camera
Have a Finepix S602Zoom which on warning display now shows ''Card not initialised''- have bought a new 4GB card- but still have the same problem.. Any ideas - software prob?
This is a common error in the FinePix product range. When you receive a "Card Error" or "Card Not Initialized" message, this indicates that your camera's memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most users will use the "delete all" feature and continue to take pictures but by doing this the file format of the card may become unstable and unusable.
Fuji recommends formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted the images will not be recoverable. So format the current cards and they should be useable again.
Sep 25, 2009 | Fuji FinePix S7000 Digital Camera
754 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
