Tip & How-To about Computers & Internet
Stop auto-starts operating systeme
To prevent Windows XP automatically restarts after a crash, all you have to do is right click on My Computer and select Properties. Now go to the Advanced tab. Click the Settings button under Startup and Recovery, then uncheck Automatically restart button. Now click on OK twice to manual control options to restart your PC.
Computers & Internet Logo
restarts automatically
If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advancedtab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If theAutomatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
I hope this has answered all your questions. If you have any other questions, please contact us at info@custompcrepair.org
Mar 16, 2011 | Microsoft Windows XP Professional
Keeps shutting down.
To resolve the issue, Please perform the following steps:
Step 1: BIOS Reset
To reset the BIOS defaults, follow these steps:
1. Restart the computer and press F2 (F10 in some Notebooks) as soon as the HP logo appears.
2. Go to Exit menu and select Load BIOS defaults or press F9.
3. Go to Exit menu and select Save changes and Exit or press F10.
This will reset the BIOS defaults. Now, when the Notebook restarts, press F8 repeatedly until the start up menu appears. Select the Safe Mode and press Enter Key to enter in Safe Mode and then perform the step 2.
Step 2 : Disable the "Automatically Restart" under System Failure:
1. Click Start, right-click the My Computer icon, then Properties.
2. Click the Advanced tab, then Settings in the Startup & Recovery section.
3. Remove the check mark next to Automatically Restart under System Failure.
4. Click OK to close the Startup and Recovery window, then click OK to close the System Properties window.
5. Restart the computer.
Step3: Reinstall Power management
To reinstall Power Management in Windows XP, follow these steps:
1. Click Start, select Control Panel, and then choose Performance and Maintenance.
2. Click the System icon to open the System properties window.
3. Select the Hardware tab and click Device Manager.
4. Click the plus (+) sign next to System Devices.
5. Right-click the ACPI Fixed Features button and select Uninstall.
6. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
May 25, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
restart at shutdown
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
Toshiba Satellite A15 problem
Most Windows XP Blue screen errors are
reolved by the following.
Run CHKDSK /R
Do this by opening "My computer"
Right click on the C: drive (most often
named "local Disk") and select
properties.
Click on the Tools tab.
Click on "Check Now"
Check "Automatically fix file system
errors" and Scan for and attempt
recovery of bad sectors"
Click Start and then "OK" on the error
that comes up.
Now reboot your computer.
This will probably fix the error.
Mar 12, 2008 | Toshiba Satellite A15-S157 Notebook
123 people viewed this tip
David Payne
David Payne
