Tip & How-To about Computers & Internet
How do I transfer my files and settings between PCs?
You need a blank floppy disk and the Files and Settings Transfer Wizard click Start and select Programs >Accessories > System Tools > Files and Settings Transfer Wizard.
Computers & Internet Logo
i1am using win xp service 2 and i want to reformat my pc to service pack 3 how do i back up my files
If you already are running XP with SP2 you do not need to reformat, just download and install SP3.
May 04, 2011 | Microsoft Windows XP Professional SP3 Full...
transfer files to a new computer?
From Maxtor's web-site, download the "MaxBlast" software.
Use it to "clone" your existing disk-drive onto your new disk-drive.
It works, and it works _very_ quickly.
Other than that, use the Windows "Files and Settings Transfer Wizard" (under System Tools, under Accessories, under All Programs) to select what you want to copy (E-mail? contacts? Files? Music?) and to burn one "aggregate" file onto a DVD-recordable disk.
Then, use the same Wizard to "import" from that disk onto the new system.
Dec 18, 2010 | Maxtor Hard Drive
Have an ACER netbook. It was running very slowly. Was told that there is zero space left on the hard drive and that a system restore is required. Would you please tell me how to do this? Thanks
I recommend you have a quick look in your documents, music & pictures folders and clean out unused/unwanted files first.
System restore is a great tool but not usually the right tool to use to free up hdd space :)
If your running on Windows I also suggest running the Disk Cleanup wizard.
Win 7 / Vista : Start -> Accessories -> System Tools -> Disk Cleanup.
Win XP : Start -> All programs -> Accessories -> System Tools -> Disk Cleanup.
Once DC has analyzed the PC it will come up with a set of options. It should be safe to select the following and Click OK to continue removing them.
  1. Temporary Internet Files
  2. Recycle Bin
  3. Debug Dump files (WIN 7 / Vista)
  4. Temporary Files
Once you click OK Windows will then remove these files from your HDD freeing up some space. Its always a good idea to run Disk Defragmenter afterwards to ensure optimum performance.
Win 7 / Vista : Start -> Accessories -> System Tools -> Disk Defragmenter.
Win XP : Start -> All programs -> Accessories -> System Tools -> Disk Defragmenter.
Select your primary O/S drive (usually C:) from the list and Click Defragment. Wait for the Defragementer to complete (It might take some time :) ) then restart the PC.
Hope this helps
BD
Sep 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
when i open facebook i get a blank page and in the comments column it shows "bigpipe is undefied"
Try this....
1. Close all applications and restart your computer.
2. Open Internet Explorer, Go to Tools >> Internet Options.
3. Click on Delete to delete history/cookies.
4. Go to Advance tab and click on Restore button.
Then....
1. Click on Start, in the start search filed type disk cleanup and press enter.
(for XP: Click on Start >> All programs >> Accessories >> System Tools >> Disk Cleanup)
2. Click on My files, select C: and select all the boxex then click on next.
3. Click on OK to complete.
Then....
1. Click on Start, in the start search filed type disk %temp% and press enter.
(for XP, click on Start >> Run >> type %temp% and press enter)
2. Press Shift+Del for all the files or folders you see there.
3. Restart the Notebook and check for the issue.
For better help, post the product model and make. Also, the operating system installed in the system. Thanks...
Sep 16, 2010 | Computers & Internet
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
170 people viewed this tip
David Payne
David Payne
