Tip & How-To about Computers & Internet
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 portwith a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10 or higher), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Computers & Internet Logo
How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Mar 08, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
Configuring a 3COM 3CRWDR200A-75 router as a repeater
Nov 17, 2012 | 3Com OfficeConnect® (3CRWDR200A-75) Router...
I want to use router as wireless extender
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers. http://www.fixya.com/support/r8279884-setting_router_as_repeater
Nov 05, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
how to make a net gear dgb111g into a dummy or bridge unit for wifi, using with bt home hub?? thank you
Aug 15, 2012 | NetGear DGB111G Wireless Router
can i use my old usr 5461 wireless max g as a repeater?
SETTING A ROUTER AS A REPEATER1. Connect your computer to the repeater router's RJ45 portwith a LAN cable. 2. Open a browser, then enter the router's URLconfiguration's IP address, This is usually something similar to 192.168.0.13. Enter the configuration user name and password. Therouter will display the various router settings.4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on thenetwork, or any other network devices. If the main router on the network is setto 192.168.1.1 then the repeater router should use a higher number (ie. 10),such as 192.168.1.10 or higher, depending on how many devices are on yournetwork.5. Disable the repeater router's DHCP server. This settingshould be on the same page as the IP address, (this may be different dependingon the make of the router). When the main router is operating normally, thisserver assigns an IP address to every device that is connected to your network.Because this router is used as a repeater, the main router on your network willstill issue the IP addresses.6. Also turn off the DNS server, if it is activated. Thisfunction will be taken over by the main router.7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model ofyour router.8. Remove all in the "Port Forwarding" section. Some routersmay refer to this as "Applications and Gaming," and it allows less-restrictedaccess to the internet.9. Set the operating mode switch to "Gateway" or "Switch" ifapplicable. Also, if the repeater router is a wireless router then disable thewireless access or set it to access point only.10. Save the settings for each page, and reboot the router.When the router boots up, the changes will allow it to act as a simplerepeater. 11. Now, place the repeater router in a newlocation and connect both routers with a Ethernet cable in each
Jul 18, 2012 | U.S. Robotics USRobotics USR5461 Wireless...
1,388 people viewed this tip
David Payne
David Payne
