Tip & How-To about Computers & Internet
Can I try reinstalling Windows if my computer loses power during installation?
If your computer loses power during installation, Windows will attempt to revert to your current operating system. You can continue to use your current version of Windows, but some features might not work.
Before you try to install Windows again, troubleshoot and eliminate the problems that might have caused your computer to lose power.
Check power cables and power strips and replace any faulty parts. After you have done this, try installing Windows 7 again, and choose a custom installation (an installation that automatically replaces your existing version of Windows).
Warning
  • A custom installation deletes all of your settings and programs. Be sure to back up your files before you begin. After the installation is complete, you must manually reinstall your programs, and restore the files you backed up.
Computers & Internet Logo
how can i install windows xp on laptop CQ60-104TU without flushing the BIOS
When your operating system stops working correctly, you might need to re-install it. In many cases, when you continue operating the same computer for years, installing and un-installing programs over and over again, sometimes certain operating system files don't work as well as they once did. When that happens, you can also start a re-installation of your operating system. If you use the same operating system for a number of years, it is often helpful to re-install the system software every now and then.
1. Put the original CD or DVD for the operating system in your CD or DVD drive.
2. Shut down your computer and restart the computer. Boot from the CD, if your system asks. This will start the installation process and will pause when a blue installation screen appears.
3. As the screen directs, press the "Enter" key to continue the installation process.
4. Press the "F8" key to continue the installation, agreeing with the Windows Operating System licensing agreement.
5. Press the "R" key on the next screen to attempt the repair process. This process will attempt to re-install all the operating system files that are on the installation disk without bothering any of the customization that you have done to your operating system. This process may take a few hours to complete, but when it completes, you should have Windows XP re-installed and working on your laptop.
I hope you find it very helpful. Best regards.
Aug 15, 2011 | Compaq Presario Notebook
I mistakenly install windows xp pro over my current operating system which is also windows xp now i want to uninstall the newly install operating system to go back my previous operating system. I had tried several ways but still i cannot revert to my previous o.s.
Hi.
What you can do is to bring the computer back to time before installing XP Pro.
Go into Start - All Programs - Acessories - system Tools - system recovery and here choose according to the calender a piont/date before installing XP PRO.
The computer will be brought back timewise to a point/date of your choise.
It will take some time to do BUT JUST FOLLOW THE INSTRUCTIONS DURING THE RECOVERY.
Enjoy
Feb 26, 2011 | Microsoft Windows XP Professional With...
You cannot vote on your own post 0 a blue screen of death states a problem has been detected and windows has been shutdown to prevent damage to your computer technnical imforation 0x00000024(0x00190203,0x81B4E960,0xc0000102,0x00000000)pplease help!!!!
Important notes
First, the condition experince with networked computers
The computer has encountered a critical error due to a network server shutdown during when operating system update were being performed.
Second, the condition experince while attempting to install a malfunct computer software. Examples include, softwares capable of alterating the operating system. Attempting to install another operating systems software on an already existing system that is incompartible would first ease the prior system making way for the new version. A critical error shut down displaying digits is what occurs.
Third, attempting to restore the computers softwares byy deleting a significant program file, especially on the operating system causes the situation experinced.
Resolution to the problem
First, perform hardware checks
1. Disconnect the computer from any networks
a. if a computer connected to a network malfunctions, disconnecting each computer leaves the remaining to continue to function like before.
2. A problem due to connecting a device that was incompartibility to the operating system, with disconnection should produce restore functionality. examples, of printers, fax machines, and pheriperal connections that are outdated in software compartible to the computer system.
3. The foreign disk incompartible to the operating system locable in the disk driver once removed from the dirvers should restore to usual functionality soon after restarting the computer.
Second, perform software checks
1. Power of the computer, powering back on after mometary delay.
2. the computer should load display the usual operating system.
3. The process would display the same error indicating a persistant problem requiring reestablisment.
A comprehensive resolution of the problem considering both hardware and software conditions explained
1. Disconnect every computer pheripheral, examples, faxes, printers, speakers, external networks, internet modems
2. power off, power on shortly after
3. wait until the compuer performs a new reconfiguration to the removed pheriperals
contact technical support
Dec 20, 2010 | Computers & Internet
I am installing os windows xp sp2 19 minutes left power shut off 3 times , when power on windows start up to mouse arrow pop up, what shall I to continue installation acer laptop?
The computer will continue to reinstall windows. It will say restarting installation, simply continue. If it stops again make sure you are using a good copy of OS CD and not a pirated one. Do a full format before attempting to install one.
Nov 28, 2010 | Computers & Internet
152 people viewed this tip
David Payne
David Payne
