Tip & How-To about Cell Phones
How to enter unlocked code in BLACKBERRY phone?
TIPS on HOW to UNLOCK
BlackBerry HOW TO ENTER NETWORK UNLOCK CODES
Blackberry Curve, 8800, 8300 8520
Unlocking can be done without SIM card inserted
Turn wireless mode off
While on the home screen click the "Settings" icon
Go to "Options" menu and select "Advanced options"
Select "SIM card"
Hold the ALT key while typing MEPE. You will not see text appear on screen while typing
You should be presented with a prompt "Enter Network MEP Code"
Enter supplied unlock code
8700c
To enter codes:
-Go to options
-Advanced options
-Simcard
-type MEPD
-type MEP press"alt tab" type 2
-enter readed mep code
7290
Entering unlocking codes:
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type "MEPD"kanan
3 - You should now see the five locking categories listed.
4 - While holding the ALT KEY, type "MEP2" kaliwa
5 - Release the alt key.
6 - You are now prompted to enter the Network MEP code (will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
7100g
go to settings , options , sim card , ten
Type 'MEPD' respectively 'MEPPD' in case phone is 7100
Usually u should see active NET lock. Now in order to disable this lock type 'MEP2' respectively 'MEPP2' if
phone is 7100 and will appear a dialog asking for code
Blackberry
5xxx, 6xxx, 7xxx Series (except for BB 7100 and 7130)
Go to "SIM card"then press the jogdial to select it
Type MEPD (not case sensitive). You will not see text appear on screen while typing
It will say "Network active"
Press and hold the ALT key (half moon looking key on the lower left side)
While holding the ALT key type in MEPE (not case sensitive). You will not see text appear on screen while
typing
When prompted enter supplied unlock code
After entering the code press the jog dial
Your phone is unlocked
Blackberry 7100, 7130
While on the home screen click the "Tools" icon
Select "Settings"
Go to "SIM card" then press the jogdial to select it. You should see the phone number and the SIM ID number
Type MEPP2 (not case sensitive). You will not see text appear on screen while typing.
Press ALT and 2 simultaneously to get number 2.
Blackberry 8100 Pearl
Select "Advanced options"
Type MEPP2. You will not see text appear on screen while typing
After entering the code press the trackball once
If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10
seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will
be permanently blocked.
alternative instructions
Insert SIM card into the device
Power on the phone and turn Wireless Off
Go to "Settings" then "Options" menu and select "Advanced options"
Type MEPPD. Please note that you will not see what you type on the screen.
alternative instructions for some Vodafone Blackberry 8100
Insert non original SIM card into the device
Go to "Settings" then "Advanced options"
Type MEPP2 while holding Alt, multitap enabled (hold [Alt], type [M] [ER] [OP] [OP] [TY]. Please note that
When prompted with "Enter Network MEP code (255 left)" on the screen, enter the 16-digit network unlock code
provided for your phone, then press Enter
Pull the battery out of the phone
Switch the phone on and the phone will be automatically unlocked
To unblock such phone, it must be taken to a RIM service centre. No outgoing calls including emergency call
is possible when the phone is blocked.
Select "SIM card"
Select "SIM card"
While holding the ALT key type MEPD. You will not see text appear on screen while typing
While holding the ALT key type MEPE. You will not see text appear on screen while typing
Blackberry 8700, 8700c, 8707
Unlocking of these models requires a SIM card inserted (active or inactive)
Select "SIM card"
Blackberry 8230 Curve
Press the "menu" key
Scroll and select "Manage connections"
Select "Turn all connections off"
Press "Escape" to go back to the "Home" screen
Select "SIM card"
Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a
personalization menu
Hold the ALT key while typing MEP2. You will not see text appear on screen while typing
Restart your phone and restore connections by following the first two steps
Blackberry 9000, 9500, 9530 Storm
Insert any sim card
Select "SIM card"
Select "Show keyboard"
8310
how
Select "SIM card"
8830
How to enter codes in BlackBerry
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPPD or MEPD (you will not be able to see the typed info)
8. Enter ALT MEP2 or MEPP2
9. Now it will say enter network mep code
Cell Phones Logo
insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
i cannot enter the pin code to unlock the blackberry.
Don't worry, try this step to insert your Blackberry Curve 8310 Unlock Code :
1 - Switch on your Blackberry Curve 8310 without any Sim card,
2 - Go to Options,
3 - Select Advanced Options,
4 - Select SIM Card,
5 - Hold the ALT Key while typing in MEPE or MEPD or MEPPE or MEPPD ( not case sensitive ) ( you will not see text appear on screen while typing ),
6 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
7 - Your Blackberry Curve 8310 will now be unlocked.
If your phone still not unlocked, it means you have wrong blackberry unlock code. Don't try it again, and go to get new and correct unlock code.
Mar 07, 2011 | RIM BlackBerry Curve 8310 Smartphone
unlock blackberry curve at&t
Yes you can use after unlock but its not possible that you can get code free it comes from server.
How many tries you left ? only 10 tries for unlocking. wrong code can lost your tries.
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set. & ACCEPT PAYPAL
***SPECIAL CHEAPEST PRICE till 31th July from one of oldest provider.***
After unlocking from this provider's code your blackberry not only work with any network, you can use your Blackberry in any part of world with any GSM networks including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry & remove restrictions like T-Mobile or any
This site will help you a lot & good email & 24/7 phone support. http://blackberryimeiunlockcodes.com/
Jul 27, 2010 | AT&T Blackberry Curve 8300 Smartphone
I'm In China, the Phone is unlocked and the Chinese Sim Card
It's a clear and fully detailed guide on how to unlock any BlackBerry :
3. Go to Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Apr 16, 2009 | AT&T Blackberry Curve 8300 Smartphone
148 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
