Tip & How-To about Computers & Internet
How to install Windows XP software,..... in Windows 7
This is a short guide on how to install the Windows XP compatible Driver or Software/application on Windows 7 system. There are many applications and hardwares which are not compatible with Windows 7. For example, many old machines/computers don't have drivers to run all the hardwares on Windows 7. Of course, most drivers have been updated by the respective manufacturers, but still there are numerous left out.
In this demonstration, I am going to use CDS/ISIS for Windows (Winisis) as the software which isn't compatible with Windows 7. I don't mean you should install this to perform the steps, but I am only taking Winisis as an example, the steps should be more or less similar and I do hope that readers will definitely understand to perform following the steps below.
Step. 1. First of all, download or save the driver/software/application setup file i.e. install usually named as "setup.exe" on your computer. You can create a folder or you can simply save the file on your Desktop. The setup file may have different names, but that's not the matter as long as you can identify which one to run. Now locate the setup.exe file, in the below example, it's "Winisis15_3".
Step. 2. Right click the setup file, and click "Properties" from the right-click drop down menu.
Step. 3. The properties "Dialog box" will pop up, cick the "Compatibility" tab.
Step. 3. Now on the "compatibility" section, click select the check box "Run this program in compatibility mode for:" and click the tab just below the "Run this program in compatibility mode for:", from the drop-down list, select "Windows XP (Service Pack 2)"
Step. 4. Now, select the "Run this program as Administrator", cick "Apply" and then "Ok" to close the Window.
Step. 5. Go to the folder where the setup file is saved, double-click to run, the Window 7 "User Account Control" warning message dialog box will pop up (if it's not disabled) click "Yes"
and follow the onscreen instructions to install the software/driver/application. The install steps will proceed ahead without any problem. Once the install is completed, restart your computer for the changes to take effect. You do not need to restart after every install, but if you are prompted to restart, do so.
Cheers!! You now have windows xp driver/software/application installed on Windows 7. Thanks for dropping by :).
NB. You can also perform this on Windows Vista to install Windows XP driver.
*Please leave comments for issues related Windows 7, I am ready to share with you all and am also glad to learn from you too..
Computers & Internet Logo
I have windows 7 need the drivers compatible with my software. pleaseeeeeeeeee!!!!
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Sep 06, 2010 | Lexmark X75 All-In-One InkJet Printer
Is Pinnacle Impression DVD SE compatible with windows 7 ultimate 64 bit - or perhaps the virtual machine emulation of XP? Thanks for your help
(make your program/application run with windows 7)
Sep 01, 2010 | Pinnacle Impression DVD SE Full Version...
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work with older files/projects made using PrintMaster 7.0?
Jun 20, 2010 | The Learning Company PrintMaster...
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with Windows 7 even though the box says XP and Vista. I have tried 4 times. Any solutions?
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
7,009 people viewed this tip
David Payne
David Payne
