Tip & How-To about Chevrolet Caprice
Where's The Fuse?
One of the most common questions asked in online auto repair forums is "Where's the fuse that goes to...[whatever]?" The reason this is so common is because in today's automobiles, 80% of all the problems experienced by the car owner are electrical in nature......(some electrical device is not working). It may be a power window, a power door lock, a radio, a tail light or a navigation system, just to name a few.
Here's the problem with that question:
Contrary to popular belief, fuses are NEVER the CAUSE of an electrical circuit problem. Blown fuses are ALWAYS the RESULT of an electrical circuit failure. I am continuously hearing the phrase "It's just a blown fuse" or "I think it's just a fuse issue". My response to that is WHAT??? There is no such thing as "just" a blown fuse! Fuses don't just go around blowing themselves out in an effort to make your day miserable. Fuses are electrical SAFETY VALVES. Any time there is a blown fuse, this means that there was an electrical overload that was threatening to burn your car to the ground!
In today's cars and trucks, there are literally miles of wire connecting all of the electrical components. Some are high amperage circuits that power things like motors and some are very low power circuits running on less than two volts for things like oxygen sensor circuits. All of these circuits, however, are connected to the vehicle battery in one way or another. All of these wires are bundled together neatly in what is called a wiring harness.
The fuse has the job of allowing enough power to run the circuit, while being weak enough to be the first part that will burn in the event of a short circuit or overload. This is so the wires themselves do not burn. When the fuse blows, it turns the electrical power off to the offending circuit.
A short circuit or electrical overload causes the wires to overheat. When the wires heat up, the plastic insulation melts off of them. The wire can then burn through the insulation in the wire next to it and cause it to overload. The next thing you know, you have a hundred different wires burning in the same vehicle because of one little short circuit.
The fuse that blew just finished preventing this from happening. It gave its life to stop your vehicle from lighting up like a bad dream from "The Abominable Torch Visits The Fireworks Factory". To replace this fuse and not find out and correct the reason WHY it blew in the first place, will only cause another innocent little fuse to have to give up its life to keep your vehicle from toasting. In this case, the first fuse will have died in vain!
If you are going to try to fix an electrical problem in your vehicle there are a few things that you must have to get the job done.
1. You need a fairly good understanding of how an automotive electrical system works. If you don't have this understanding you are headed for certain disaster and disappointment. Many community colleges as well as several online educational resources offer training in this area. I highly recommend getting at least some basic training. Even if you don't use this training to fix your own car, it will help you to understand what is going on at the shop when you take your car in for repair.
2. At the least you will need basic electrical system testing equipment. A digital volt/ohm meter and a 12 volt test light with a long cable will do in most cases. A set of long test leads, alligator clips, a few jumper leads, and some back-probing pins are also recommended. You want the long leads because it is always best to connect directly to the battery ground when testing power circuits and directly to battery positive when testing ground circuits. You can waste a lot of time and effort otherwise. Also be sure to get QUALITY equipment. I have seen a lot of misdiagnosis as the result of using a cheap test light that only works when it wants to.
3. You will need the wiring diagrams for the vehicle you are working on. This falls under item #1 above...you also need to know HOW to USE a wiring diagram. In the old days, automotive electrical systems were pretty simple and you could poke around with a test light until you found what you were looking for. In today's computerized cars and trucks, you have to know EXACTLY what you are poking on. Probing a wire with the wrong piece of equipment or with the wrong set-up can cost you a computer module in the blink of an eye.
Simply replacing a blown fuse will not fix your car. If you are not willing to go through all this and you are experiencing an electrical problem in your vehicle, I highly recommend that you don't waste your time and effort looking for the fuse. Probably 95% of all automotive electrical failures do not include a blown fuse anyway. The phrase "Check the fuse" is highly overrated.
-DTTECH
ASE Certified Master Automobile Technician
Other articles by dttech:
My Car Won't Turn Over
What Else Could Be Wrong?
Cars & Trucks Logo
2009 Kia Sorento Diesel. Where is the fuse for the immobilizer please.
Question edited for clarity. So few words, so many errors.
Question moved to model category.
There isn't one. The immobilizer is a joint function of the ECM BCM And antitheft module.
Whatever you are trying to do, won't work. You can't find a way to work around the system, you have to fix it. An auto electrician with a professional grade scan tool computer can diagnose in 30 minutes and reprogram.
https://www.google.com/search?q=mobile+auto+electrician+near+me
KIA Sorento (BL; 2003-2009) fuses and relaysFuse Box Diagramshttps://fuse-box.info > kia > kia-sorento-bl-2003-2009...
The fuse box is located behind the cover below the driver's side of the instrument panel. The location of the fuses in the passenger compartment: KIA Sorento ( ...
KIA Sorento (2007 - 2009) - fuse box diagramAuto Geniushttps://www.autogenius.info > kia-sorento-2007-2009-...
Apr 12, 2018 - KIA Sorento (2007 - 2009) - fuse box diagram · Driver-side kick panel · Engine compartment · Alternator fuse.
4answers
I need to know where I can go to get a manual diagram for a 1996 Cherokee jeep sport fuse box?
Like answer #1, when I bought my 1993 Jeep Cherokee, one of the first things I ended up doing was go to & join the
cherokeeforum.com, i.e. cherokee-forum-dot-com....
I've found that whenever I need advise, or answers to any questions with my vehicles, I look for the forum for that vehicle. 99.9% of the time the folks in the forums give you honest answers..... I even subscribe to a few YouTube Channels, like the one for my 93 Cherokee. That guy is not only smart when it comes to 1990s-2000s Jeep Cherokee's/XJs, he's always doing some sort of repair or modification to one of his Cherokee's or Grand Cherokee's..... Hope this helps all you Jeep XJ Folks out there....
2answers
Where is the cigarette lighter Fuse and access to the cigarette lighter
Some of the newer cars do not have cigarette lighters. You can probably have someone install one for you.
what causes the 30 amp starter/HBL fuse to blow?
USA car?
what engine , gas or diesel.,what size is it?
where is fuse located, Green = 30amp
in the cab, no ,no 30amp in cab. so is below.
or in the PCD box under hood,
here is PDC,
here is fuse f15, which i think is HBL
diesel HBL is f15
gas HBL is f11
fuse 11 is 3 up from bottom right. gas only.
fuse 7 is 30amp too in pDC
and runs headlamp controls or DRL, got DRL
fuse 8 diesel? see fuse 7 answer gas.
in canada, they have DRL , daylight running lights.
we dont.
but fuse 7 30a runs that.
PDC fuse 4 30am runs ASD and if blown diesel engine dies.
HBL is fuse 15 or F11
or is Fuse 7 or 8.
which blew, ive not a clue,
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service4f6c1760-6974-4060-8f0c-4061f5931480.jpg26005253-2mkpgvahazoelzt2oyasucxh-2-2.jpg
2answers
heater control (on & off & speed) just quit this morning. what are the probable causes?
Heater Switch question - Suzuki Forums: Suzuki Forum Site
www.suzuki-forums.com/suzuki.../48603-heater-switch-question.html
Nov 2, 2011 - 10 posts - ‎6 authors
(1993 suzuki sidekick) I have checked the resistor and it is fine. ... switch is part of entire assembly that operates heater controls, (S--T, S--T!!) ... 1993 sidekick blower switch Part number 74460-64A0
Nov 5, 2011
Removing heater control ?
Oct 5, 2011
Scan Code P0031
Jun 18, 2011
heater blower resistor location
Jan 28, 2008
More results from www.suzuki-forums.com
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
