Tip & How-To about Cell Phones
How To Soft Reset, Hard Reset, and Factory Reset Your LG Quantum
If you are uncomfortable with resetting your phone, or unsuccessful in fixing the problem, please contact the phone company for which you receive service from for help with resolving your issues.
Soft reset
To perform a soft reset, power the device off and back on.
  1. With the screen unlocked, press and hold the Power key to turn the phone off.
  2. When the phone is off, press the Power key to turn on the phone.
Hard reset
  1. To perform a hard reset, remove and re-insert the battery.
  2. Press the Power key to turn on the phone.
Master reset
IMPORTANT: The device will be set back to factory settings; all data stored on the device will be lost. The device may not be functional for up to 15 minutes after a master reset is performed.
  1. From the home screen, swipe left to expose your app list
  2. Tap Settings
  3. Scroll down and tap about
  4. Tap reset your phone
  5. Tap yes to confirm, then tap yes to confirm again
That's it! Your LG Quantum will now be wiped. It will then reboot and you'll be left with a factory fresh phone.
Cell Phones Logo
"Encryption Unsuccessful" screen on Droid RAZR HD
Have you tried to perform a HARD RESET on your phone?.
to do this you first need to power off your phone.
With your phone POWERED OFF press the VOLUME UP and VOLUME DOWN keys AT THE SAME TIME. Once you have depressed BOTH VOLUME KEYS press and hold the POWER key.
Once you have depressed ALL 3 KEYS ON THE SIDE OF THE PHONE the "BOOT MENU SCREEN" should appear.
When the "BOOT MENU SCREEN" appears, release ALL keys select the "RECOVERY" option, the phone will re-boot and you will see the "Motorola" logo. Eventually the "Motorola" logo will be replaced by the "ANDROID IN DISTRESS SYMBOL" (the "ANDROID" with an exclamation point in front of him). Press ALL 3 keys on the side of the phone once again, tap and release the VOLUME UP key, you should then see a BLUE MENU SCREEN,
oNCE YOU SEE THIS blue menu screen SCROLL DOWN TO THE "wipe data factory reset" OPTION.
oNCE YOU HAVE SUCCESSFULLY COMPLETED THESE STEPS THE hard-reset PROCEEDURE WILL BEGIN. WARNING THE HARD RESET PROCEEDURE WILL ERASE ALL OF THE DATA THAT IS CURRENTLY STORED ON YOUR PHONE SUCH AS PICTURES, MUSIC, YOUR CONTACT LIST and so on. SO YOU SHOULD DO A BACKUP BEFORE YOU START THIS PROCEEDURE. I hope that this information is helpful to you!!!.
Apr 07, 2014 | Motorola Mobility Droid RAZR HD
Have a dect 2188 series phone. I would like to no how to turn off the voice message notification, the light at the top of the hand held receivers blinks all the time. I try resetting but it starts blinking again in a few minutes there are no messages
You have unheard messages on the voicemail system provided by your telephone company. This system takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 20, 2011 | Uniden Cordless Phone
My lg quantum is giving a a message:"retry again
Soft reset
  1. With the screen unlocked, from the top panel, press and hold the Power key to turn on the phone off.
  2. When the phone is off, press the Power key to turn on the phone. press and hold the Power key to turn on the phone off.
Hard reset
Master reset
  2. Tap Settings
Feb 10, 2011 | LG Quantum (16 GB) Smartphone
signal strengh
I assume this problem was resolved. If not, please contact me and I will walk you through the solution. It always helps to know the provider name. Most cell phones are only as good as the towers they connect to. If your phone is not connecting to the local towers correctly you need to contact your service company for a tower update code.
Please let me know if I can help further.
Ken
Jul 29, 2007 | Motorola Mobility Moto Q
1,821 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
