Tip & How-To about Keurig Platinum B70 Coffee Maker
Keurigs with Side tank not pumping water
Those of you having a pumping problem with the Keurigs with side maounted tanks. It seem that the screen in the base when you liftout the tank you can see it, has a tendency to vapor lock due to the small mesh and pump height. I corrected this by putting 4 larger holes in the screen which is plastic with a pointed object just be careful not to go to far down or you will puncture the hose for the pump. After doing so I have not had a problem with my pump supplying water for the last 2 weeks to the heat tank, if your pump is not humming or working this will not work. This is a fix for those that remove the tank and set it back and the pump works when this is done you are forcing water through the screen breaking the vapor lock so try it, if it works fine
Keurig Platinum B70 Coffee Maker Logo
i received a coffee marker about 3 years ago and it always only made 1/4 cups of coffee i never thought anything about it until i went over a friend of mine they have the same one and theres make 3 differnt sizes
Clean it out. If there is a partial clog, some Keurigs will pump some of the water back into the tank. See if this is happening when you brew. Then clean the brew head water input (stick a paper clip or similar up the shaft and wiggle it). If this is still a problem, replace the filter in the water tank.
Mar 05, 2014 | Keurig B60 Coffee Maker
pump body and bracket position bolt mount repair.
lol too much power for the pressure tank back off the flow or get a new pressure valve 50 psi is good pressure how big is the tank what is the gauge rated for all these \details need to be spoken in order to answer sounds like you want some water lol its sucking air too tank doesn't need air it has to be primed first tighten the bolt and now you have to use pipe sealant white putty to seal those nuts and bolts back up pump cant suck air
Feb 28, 2017 | Flotec Plumbing
will a inline fuel pump work on a 1990 honda
it could but for the maount of labor to modify the line and electronics you may just as well replace the one in the tank
Feb 12, 2011 | 1990 Honda Accord
looses prime.
Feb 09, 2011 | Keurig Platinum B70 Coffee Maker
how do I replace a tank maounted fuel pump on a jeep grand cherok
its not real hateful especially if the tank is low on fuel....you need to drop the tank out of the vehicle....the electrical connecto is on the drivers side in front of the tank mounted to the frame,,,,disconnect the fuel lines and undo the nuts holding the 2 straps...lower the tank and there is a plastic ring holding the pump in...loosen it counter clockwise and remove the pump
Jan 01, 2009 | 1995 Jeep Grand Cherokee
2,242 people viewed this tip
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
