Tip & How-To about Office Equipment & Supplies
Reset Canon printer errors and reset Ink Waste Absorber Full
On the Canon series machines MP160 and MP250 and MX470 I have been able to fix most error codes with this procedure: Turn off printer. Hold the Stop/Reset button (triangle in a circle) down and hold while pressing and holding down the ON button. Keep holding both down for 5 seconds then take finger off the Stop/Rest button and then press that button 4 times. This puts the printer in service mode. Let go of the buttons and press stop/reset two more times. This is a service mode signal to recycle the EEPROM and clear errors. Now you can turn the power off. If you have trouble turning off, then hold the power button for four or five seconds and let go to turn off the printer. When it restarts it will act like the printer was new. If you want the WASTE INK absorber is full warning set back to reset you would press the Stop/Reset button six times instead of four. TIP: If printer won't turn on, remove power code for 60 seconds and replace it, then power on.
error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
error p08
Repair, Canon MP258 code error P08
1. The printer is off and plug the power cord.
2. Press the button STOP / RESET and hold, then press and hold the POWER button
3. POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed
4. Release both buttons simultaneously
5. The printer will proceed in a while, then the LCD panel will show the number zero (0)
6. Computer will detect NEW DEVICE (Canon MP258 series Printer (Copy 1)), Ignore it
7. Press the power button, then the printer will turn off. If the printer does not turn off, unplug the power cord.
8. Press the power button again, then the printer will be ready to use.
Nov 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
my printer mp250 error p07 led flash orange
The Error P07 means your printer Ink absorber is full. See complete Error code Canon mp250/258 Printer
Solution: How to reset it you can get detail on the web too. here is the link How to reset Canon MP 250 Series includes Manual Reset and Permanent Reset with Tools
May 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
how to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
475 people viewed this tip
k24674
