Tip & How-To about Computers & Internet
BIOS error, System Failure, Boot failure? ? Lets FIX it.
I guess everyone working on a computer is familiar with the word BIOS and what exactly it is? Still let me tell that BIOS is intelligent software that enables the system to start. I need not to mention that system here refers to computer. Bios facilitate the booting of a system without human intervention. BIOS is a program that is installed in a hardware chip known as ROM chip.
This single word matters a lot to most of the users who face various problems when their system failed to start normally or make some unusual activities. Each time I visit any technical forum I see a lot many users posting their problem regarding BIOS. I researched on internet about BIOS errors and from my knowledge and experience I am posting this piece of help for those who find themselves helpless in getting a solution to BIOS problems.
Sometimes BIOS itself provide a troubleshooting to most of the problems. When you power ON your system it give beep sound. Checkout some beep codes
1 short Beep indicates System is OK (Acceptance Beep)
Continue long Beep tells RAM Problem
1Long 3 Short Beep confirms RAM Problem
2/3/4 short Beep --its time to Check the RAM & Video Card
By now most of you have found some clue about the problems you are facing. Now learn about POST faults
1) K/B Error/ NO Keyboard present
· Check the loose cable connector
· Cable may be bad (Keyboard)
· K/B itself may be bad
· Check the physical condition of K/B connector on M/B
· If all these are ok & problem is still processed
· Than replace the keyboard port
2) Floppy disk drive Fail
· loose data & power connector of FDD
· Data cable may be bad (FDD)
· Load the CMOS defaults
· Floppy disk drive itself may be bad
3) CMOS Checksum error
· CMOS battery has gone bad replace it. (Weak)
· Check the CMOS jumper it may set on clear
· If the entire ok than check the CMOS battery jack, it may be bad
4) Invalid System Disk, Insert System Disk & Press enter when ready/ NTLDR is Missing
· Check the root directory; it may be formatted or missing bootable files.
· Repair the Windows or Reinstall the operating system.
5) Disk Boot failure, Insert System Disk & Press enter when ready
· Hard Disk check in POST Detected or not
· If not Detected Check the power cable
· Check the Master/Slave jumper setting.
· Also check BIOS setting
6) Computer gives message: Your computer has a serious problem
Back up your data & replace your Hard Disk
This error message is displayed due to the SMART option. This scans the HDD for errors, if it detect the errors than it show the above message. Follow the error message & back up your data on to another drive.
I tried to explain most of the problems along with their solutions. There could be a lot more solutions for the problems. Make your own search and try to fix BIOS problems at your own home.
Forward this to all those who need help!!
SOVI
Computers & Internet Logo
How to turn on keyboard backlit on Compaq CQ57 laptop?
CQ-nnnnn what is nnnnn , may Cq57 made, all different nnnnnn
QC-100,.-200.,300, 400, series
your service tag tells you the full model number.
nor the OS (unstated)
XP, VISTA, W7 or W8?
this is what was used for the full series of production runs.
and they are NOT THE SAME.
tell what BACKLIT means. LEDs dead but at least name ONE>?
Please tell the helper this.
what OS first.?
tell exactly what Backlits (lights) fail, name them.
caps lock or ? what? give examples of what fails and what you are attempting to do..
on my newer HP, there are no keyboard lamps at all
not one but the HP has back panel that glows for that.
but needs the HP software loaded to make that work
only HP software works on that feature, period.
what operating system is this.?
the CQ57-400 is the last series is this it. why must i guess?
support for it is limited to this.
ill guess 400 for you as 1 example
then ill guess w7 32b
then you see this and load all these driver.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq57-400-notebook-pc-series/5186820
now il guess 100
here
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq57-100-notebook-pc-series/5059083
looks like last one made was 2012 (Compaq ended in 2013 at HP)
so has support until 2022. at HP.com
load all your drivers for you PC on the HP page.
skip BIOS. (line)
the problem here is HP used 2 processors here.
Intel
and AMD
mixing drivers up is problematic. here.
takes skills to do this.
why not ask at HP do this is.
real HP forums.... BINGO?
https://h30434.www3.hp.com/
Aug 02, 2017 | Compaq Computers & Internet
GB10186128
try another different network. or a different code. Actually why not try explaining what exactly you are referring to... is this for some software? Are you trying to communicate in code with some alien life form on another planet using Seti? Anyone's guess as to what you are asking is just that a guess, not an intelligent answer, but then your question is not intelligent either.
May 04, 2013 | Computers & Internet
BIOS Update
You didn't state what the operating system is, your brand and model of BIOS or what the problem is you are trying to correct. You should state exactly what the problem is you are experiencing and why you think a BIOS update is likely the answer. Having said that, BIOS updates are usually a simple process, download the update and boot to the USB flash drive, CD/DVD or floppy containing the update. Follow the mfg's instructions exactly. If you are given an opportunity to back up your current BIOS, you should do so.
Even though this is relatively simple, it shouldn't be attempted by anyone not familiar with this type of process. A failed BIOS update can very easily render the computer totally useless until a new BIOS chip is installed, even if that is an option. Given the way your question is worded, I'd hazard a guess that you should have a qualified technician do this for you.
Aug 21, 2011 | Computers & Internet
Presario F700 Wireless
You are f****d. This is a hardware problem, my sister-in-law is having the same problem. I probably have to figure out how to order a replacement part. Hopefully the wireless card isn't directly soldered into the mainboard. But I imagine it is. Which would mean an entire mainboard replacement. Which would mean buying a new laptop since it's not worth the replacement.
Next time. Get a mac. I'll tell her the same.
Oct 25, 2008 | Compaq Presario 700 470024-192 Notebook
397 people viewed this tip
David Payne
David Payne
