Tip & How-To about Hisense LCD1504 15 in. Television
Hisense co for tv
I finaly got hold of the company at 1-888-935-8880 have your tv modle number. our tv locked out by it self when we were using a universal remote .they wonted to charge me $35.00 for a new one but i argued with them that it was not my flult. so now they are sending me a referbashed one. GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hisense LCD1504 15 in. Television Logo
I accidentaly turned the FPA lock on my TruFlat RCA tv and the original remote broke. i just bought a RCA universal remote from best buy. now how do i get rid of the lock?
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Aug 24, 2011 | RCA TruFlat 27F520T 27" TV
my fca is lock on my tv how do i get it off
Hello
You must have its original remote control handset to unlock the FPA lock. If you haven't one with you now, try to muy a new one, or get it gathered from any of your friends or relatives who owns the same modle RCA tv; just to unlock the FPA lcok of your TV. After unlock, you can use any remote control to operate it. To unlock the FPA lock try the folloing porcedures. One amoung it will surely unlock your TV.
OK.
Jul 05, 2011 | RCA TruFlat 27F520T 27" TV
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Jun 02, 2011 | GE GTD120 System
locked control pad
Try a Logitech Harmony universal remote, they can be uploaded with the drivers from the internet and this might do the trick. Otherwise you can contact Samsung and ask for a replacement of the original remote.
Jul 05, 2008 | Samsung SyncMaster 403 T 40" LCD Monitor
re: Vchip code
you need is factory setting!
Oct 05, 2007 | Panasonic PV-C1321 13 in. TV/VCR Combo
1,696 people viewed this tip
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
