Tip & How-To about Computers & Internet
Tricks Clean an LCD Screen
Enhance. Turn off your LCD monitor can be spots or areas that need to be cleaned more observable.Dust it off. Then use the microfiber cloth and wipe carefully collected the dirt off the LCD display.Use a suitable cleaning liquid. You can buy a cleaning kit, which are usually manufactured specifically to keep your LCD screens in the best conditions. There are LCD natural cleaning products and take into account.Work with the correct tissue. When cleaning LCD screens, use a good old cotton shirt or a handkerchief or buy special wipes to thoroughly clean the LCD screen. Spray cleaning solution on the cloth and clean with gentle circular motions. Let dry. Make sure your monitor is completely dry before using again.
Computers & Internet Logo
Sony VAio touchscreen hypersensitivity
Step 1:
Touch screen monitors are both input and output device as they receive and display information from one peripheral device the monitor screen without the use of mouse or keyboard. They are used in a variety of different applications such as point of sale (POS), cash registers, ATM machines, among others. Touch screen monitors are very sensitive so proper cleaning and maintenance is of utmost importance to maximize its performance and prolong its life. Follow these cleaning steps:
Turn off both the computer and touch screen. This way, you can see everything that needs to be cleaned. Some touch screen applications has a cleaning mode which turns off the screen for the specific purpose of cleaning. However, the monitor's brightness can make you miss some areas. Wet a soft, lint-free or microfiber cloth with distilled water. Wring out as much water as you can. Make sure the cloth is damp but not wet. Wipe the screen in a gentle motion to remove dust, oil, or fingerprint smudges off. Another option is to use a screen cleaner kit that includes antistatic wipes. You can buy this at various electronic or online stores. Spray a little solution on a wipe then rub it gently across the screen. Finish cleaning the touch screen with a dry lint-free cloth to wipe any excess moisture, then turn it back on.
Feb 23, 2013 | Sony VAIO Computers & Internet
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me easy procedure of cleaning my ViewSonic LCD Monitor screen. email: amdesh1@gmail.com
Hi
Time Required:
Cleaning a flat screen (LCD) monitor usually takes less than 5 minutes Here's How:
  1. Turn off the monitor. If the screen is dark, it will be easier to see the areas that are dirty or oily.
  2. Use a dry, soft cloth and very gently wipe the screen. A great choice would be the microfiber type of cloth used to clean eyeglasses.
    See Tip #1 below for kinds of cloths to avoid.
  3. If the dry cloth did not completely remove the dirt or oil, do not press harder in an attempt to scrub it off.
    Pushing directly on the LCD screen can often cause pixels to burn out.
  4. If necessary, dampen the cloth with distilled water or with an equal ratio of distilled water to white vinegar.
    Many companies also sell small spray bottles of special cleaner for flat screen monitors but the vinegar mixture is usually just as effective.
    See Tip #2 below for products to avoid.
  5. The plastic edge that surrounds the screen can be cleaned with any multipurpose cleaner but take care to avoid contact with the screen itself.
Tips:
  1. Avoid using paper towels, toilet paper, tissue paper, or something like your shirt to wipe the LCD screen. These non-ultrasoft materials can scratch the screen.
  2. Avoid cleaning products that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the materials that the LCD screen is made of which could yellow the screen or cause other kinds of damage.
  3. Never spray liquid directly on the LCD screen or it could run inside the monitor and cause damage.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
cleaning
It is recommended to use a simple alcohol solution to clean an LCD or PLASMA screen. This solution is made up of 1 part distilled water and 1 part 50% isopropyl alcohol. Be warned that isopropyl alcohol is flammable.
50% isopropyl alcohol is very common. If you find 70%, 91%, or 99% isopropyl alcohol, adjust the formula to use less alcohol and more distilled water.
By mixing these two in a bottle, you will produce a model cleaning solution. Remember not to use tap water -- only use distilled water.
Do NOT use tissues/Kleenex to wipe your screen. That is as ineffective, because they will leave little tissue particles all over your screen . Try and find some microfiber cloth to clean your screen. Cloths that come along with prescribed glasses are usually good.
You may want to clean the rest of the actual screen before moving onto the LCD or PLASMA part. First dampen the cloth with the solution. You should never spray any sort of liquid directly onto the screen. Wipe the screen gently from top to bottom and wait for it to dry.
Be careful not to let the cleaning solution leak into the sides of the monitor. Also, be certain that you do not press hard on the LCD or PLASMA screen. You can permanently damage an LCD or PLASMA screen by pressing on it too hard.
If there is just dust on your screen, there is no need to fully clean it. To remove dust all that must be done is to wipe it away with a microfiber cloth. Simply wipe your screen from end to end gently with the cloth. For smoke filled room, It would be good to clean it once a month when the smoke is not around during cleaning.
Apr 13, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
cleaning lcd screen
It is recommended to use a simple alcohol solution to clean an LCD screen. This solution is made up of 1 part distilled water and 1 part 50% isopropyl alcohol. Be warned that isopropyl alcohol is flammable.
Do NOT use tissues/Kleenex to wipe your screen. That is as ineffective, because they will leave little tissue partiels all over your screen . Try and find some microfibre cloth to clean your screen. Cloths that come along with prescribed glasses are usually good.
You may want to clean the rest of the actual screen before moving onto the LCD part. First dampen the cloth with the solution. You should never spray any sort of liquid directly onto the screen. Wipe the screen gently from top to bottom and wait for it to dry.
Be careful not to let the cleaning solution leak into the sides of the monitor. Also, be certain that you do not press hard on the LCD screen. You can permanently damage an LCD screen by pressing on it too hard.
DUST:
Apr 07, 2009 | Sanyo Televison & Video
flatron monitor screen - how to clean
Use a microfiber cloth and they also sell a product at wall mart in electronics for flat screen tvs monitors and so forth just for the purpose of cleaning them. But a microfiber cloth should handle the bulk of it. if not go to walmart and take a peek.
Aug 24, 2008 | Gateway FPD2275W LCD Monitor
134 people viewed this tip
David Payne
David Payne
