Tip & How-To about Computers & Internet
Benefits of creating Restore Points
The Microsoft Operating Systems have a Wonderfull feature, "System Restore" by using this feature, We can keep our system running and save the improtant data by creating Restore points. Whenever a driver is installed, or a software installed, or upgraded, A restore point should be created First, so as to keep the system back to normal status if any problem occured after installing drivers or softwares on Pc
Windows System Restore
1)Click Start---->All Programs---->Accessories---->System Tools---->System Restore---->Creat Restore Point----> Click Next Button ----->Enter the name for Restore point---->Click Creat button
For Windows XP
Computers & Internet Logo
restoration problem
How often are restore points created?
Restore points are created automatically every day, and just before significant system events, such as the installation of a program or device driver. You can also create a restore point manually.
How much hard disk space does System Restore require?
To store restore points, you need at least 300 megabytes (MB) of free space on each hard disk that has System Protection turned on. System Restore might use up to 15 percent of the space on each disk. As the amount of space fills up with restore points, System Restore will delete older restore points to make room for new ones.
How long are restore points saved?
Restore points are saved until the hard disk space System Restore reserves is filled up. As new restore points are created, old ones are deleted. If you turn off System Protection (the feature that creates restore points) on a disk, all restore points are deleted from that disk. When you turn System Protection back on, new restore points are created.
The restore point is a built in utility by microsoft, you can't have the option to configure the settings!!!
Jul 15, 2010 | Microsoft Windows XP Professional
Is there system restore downloads to make CD for Gtwy MCE?
Well a restore CD/DVD can be created by you and kept for your use in case any crash(system) and anyway you can keep on working and save your work as we normally do. You can also create the restore CD now if you want to!............sodeep
Apr 10, 2009 | Microsoft Windows XP Media Center Edition...
system restore disable
Open your system properties. Check to make sure the system restore feature is enabled. I had to do this on my old computer as you have to tell the restore feature how much hdd space to dedicate to restore functions. Hope this helps & please remember to rate my answer. Thanks.
Dec 30, 2008 | Microsoft Windows XP Professional With...
restore feature on windows xp home edition
Power001:
You have to create restore points first in order for this feature to work, to fully understand the system restore please go through this informative article:
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
Hope that helped!
Dec 10, 2007 | Microsoft Windows XP Home Edition
684 people viewed this tip
David Payne
David Payne
