Tip & How-To about Computers & Internet
If resolution of monitor set to higher than it limit
Hello
Many times it may happen that the resolution of the monitor is set to higher than its limit causes the monitor to be in off state and thus make the system inoperable to overcome such problem you can perform some usefull tips as follows
Start the system, after a few minutes just click the Right mouse button and on the keyboard press Down Arrow key for "Seven times" then press Right Arrow key one time then press Down arrow key again once. Then press Enter. The resolution should set to be 800,600 thus Starts the Monitor again to normal
Computers & Internet Logo
My computer turns on but the screen remains black. What should I do?
The problem can be solved by these steps
1) Check the Video connector properly connected to PC
2) Monitor power supply cable fault
3) The VGA card is not working properly
4) The screen resolution is set to higher than the monitor supported resolution limit
The Best way to solve it replace monitor and see it is working properly
In case the monitor still stay blank you should check the VGA card
Try to start cmos setup and see whether the monitor still remains blank then it's VGA problem
Feb 07, 2011 | Compaq Computers & Internet
resolution is out of range.. when i switch on the computer and tried to switch on tv card then " input no support " appears...how can i resolve this
Maybe the resolution you set on the tv tuner is higher than the monitor's resolution, thus the error in displaying the tv. After you turn on the tv tuner, try to change the resolution from the remote control several times, maybe you can find one that your monitor can handle. Good luck!
Dec 09, 2010 | KWorld 1680 TV BOX HIGH-RESOLUTION...
nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
Anyone know a way to increase the resolution past 1024 x 768?
First, you might want to check what the maximum supported resolution of your monitor is. You can do this by looking it up on the internet or referring to the owners manual. If you cant find that information, in your graphics properties in Windows XP, click the advanced button beneath the color settings and click the monitor tab. Make sure the model listed under 'Monitor Type' matches the monitor you have. If it does, see if the 'Hide modes that this monitor cant display' box is checked. If so, the maximum resolution is limited by your monitor and you may have to upgrade the monitor to go any higher. If the model does not match, you can try the following: click Properties->Driver Tab-> Update Driver and either load the correct ones from the manufacturers web site or use one of the Standard Monitor types provided by the windows Driver library. Be warned though: If you select a standard type with resolution higher than your monitor supports, it will not display correctly at settings higher than 1024x768, and you may have to wait for windows to change the resolution back. Another thing you can try is unchecking the 'Hide modes that this monitor cant display' box, clicking ok, and setting the resolution to something higher than 1024x768, but the same warning applies! If it does not display correctly than you know for sure that the monitor is the limiting factor.
Nov 09, 2007 | Sharp LC 28HM2 28 in. Flat Panel LCD...
oblong pictures
The issue here is that you have a low resolution picture and a high resolution display. Windows is "stretching" the smaller, low resolution picture so that it will fit across the larger area, thus distorting it. Right click on the desktop and select properties. Go to the Desktop tab. There should be an item there for position. Is it set to Stretch? If it is, then this is causing the problem. Set it to center, and it should appear fine. If you want to keep this from happening: 1) User higher resolution pictures. 2) Turn down the resolution on your screen (this can be done from the Settings tab of display properties).
Oct 01, 2006 | Samsung SyncMaster 940BE 19" LCD Monitor
175 people viewed this tip
David Payne
David Payne
