Tip & How-To about Computers & Internet
How to install Graphics Drivers, Nvidia and AMD Radeon!!!
In order to get the best performance out a device one needs to have the most current/latest drivers installed on your computer system. The latest drivers provide better performance because they enable your operating system to make better use of the device, this therefore means the device operates effectively.
Today you will be learning to install the latest drivers for your graphics card, so your computer can run at a higher resolutions and give you the best performance available from your graphics card.
The manufacturers of Graphics Cards are shown below, click the makers name to download the drivers.
Nvidia Graphics Driver for Nvidia made Graphics Cards.
AMD Graphics Driver for AMD/ATI Radeon made Graphics Cards.
Select your Graphics Card model and Operating System.
Download and install.
Note: Only use the drivers provided for your make and model of graphics card!!!
Enjoy!
damnor01
Computers & Internet Logo
Not sure if the problems are related but my hp pavillion dv7 - 1130us hangs up when trying to power down and must use a hard (pwer button) power down. Also, there are 4 USB ports all of which are no longer allowing the devices connected to them to work although the computer "sees" the devices except one port has the wireless mouse connected to it and it still works - please help!
It sounds like you need to download and install the latest firmware update and drivers for your laptop. I have included the link to your laptop. You need to select your original OS and and download the firmware and flash utility to install it and do so. The update all of your drivers to the latest driver available from this site. Allow it to override any driver you currently have. This should fix your issues and restore your system to working order.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3795407#N661
Jun 20, 2011 | HP Pavilion dv7-1130us laptop
dvd cd rom [ code 10 ] does not work
The Code 10 error code is generated when Device Manager has insufficient information or the error that is bubbled up by the device drivers is not recognized by Device Manager. Additionally, this error may occur when one of the drivers that the device needs does not start. If many drivers are being used by a particular device, it can be difficult to determine the one that failed.
The Code 10 error resembles the following: This device cannot start. (Code 10) The most common resolution is to update the drivers that are associated with the failing device. To do this, follow these steps:
  1. In the device's Properties dialog box, click the Driver tab.
  2. Click Update Driver to start the Hardware Update Wizard.
  3. Follow the instructions to update the driver.
Note You may be prompted to provide the path of the driver. Windows may have the driver built-in, or the driver files may still be installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site. uparrow.gifBack to the top Typical Code 10 error issuesThe Code 10 error pertains mainly to hardware and device driver issues or to compatibility issues between hardware drivers and additional software that is installed in Windows. Therefore, we recommend that you troubleshoot these issues by focusing on device drivers, on device configuration issues, and on hardware compatibility issues. Incompatible, outdated, or corrupted device drivers If you suspect that the Code 10 error is related to incompatible, outdated, or corrupted device drivers, try the following troubleshooting methods. Method 1 Update the hardware's device driver through Windows Update. To access Windows Update, visit the following Microsoft Web site: http://update.microsoft.com Method 2 Update the device drivers from the vendor's Web site. Follow their installation or update instructions.
  • If the device was preinstalled on the computer, visit the computer manufacturer's Web site.
  • If the device was installed after the purchase of the computer, visit the device manufacturer's Web site.
  • If the device was preinstalled on the computer, and the computer manufacturer does not have an updated driver for the device, visit the device manufacturer's Web site.
Note Make sure that the device drivers that are being installed are compatible with your current Windows version and platform.
Note In reviewing customer feedback, many of the Code 10 error issues are related to devices connected by using a USB port. As mentioned earlier, make sure that you have the most current drivers installed for the device together with any updates for Windows. In the specific case of Windows XP, review the following article to determine whether it applies to your situation: 925196 A computer that is running Windows XP cannot detect a USB flash drive, an Apple iPod, or an external hard disk drive
If you are running Windows XP and cannot install Windows XP Service Pack 3, review the following article to determine whether it applies to your situation: 940514 USB devices do not work after you disconnect and then reconnect a USB hub from a computer that is running Windows XP Device configuration issuesIf you suspect that the Code 10 error is related to missing software updates and service packs, try the following troubleshooting methods:
  • Install the latest Windows service pack.
  • Use Windows Update to install the latest updates for Windows. To do this, visit the following Microsoft Web site: http://update.microsoft.com
  • Install the updates that are specific to the computer or to the device. To do this, we recommend that you visit the computer manufacturer's Web site or the device manufacturer's Web site.
Software and operating system updatesIf you suspect that the Code 10 error is related to missing software updates and service packs, try the following troubleshooting methods:
  • Use Windows Update to install the latest updates for Windows. To do this, visit the following Microsoft Web site: http://update.microsoft.com For more information about how to obtain the latest Windows service pack, click the following article numbers to view the articles in the Microsoft Knowledge Base: 322389 How to obtain the latest Windows XP service pack 935791 How to obtain the latest Windows Vista service pack 889100 How to obtain the latest service pack for Windows Server 2003 968849 How to obtain the latest service pack for Windows Server 2008
Jun 12, 2011 | Dell Computers & Internet
up date map
In order to update your Garmin Nuvi 205W's system version, you'll need to download software which checks your unit's current version and updates it to the latest version. The current version available is 2.9.1.0 as of December, 2009. Garmin makes it easy by installing a browser plugin instead of having to install a software package. The WebUpdater plugin can be downloaded here:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
In order to install the plugin you must first agree to the license agreement. You will then need to close all of your open browsers that are open on your computer to finish the install. Once you have, the plugin will start to install. To finish the system update, Garmin lists several steps on a page;
  • Disconnect your 205W from your laptop or desktop and let it restart
  • Once you see the main screen, you can connect it back to your computer and wait 30 seconds.
  • On the next screen, click the 'Find Devices' button and then click the 'Next' button.
Once your computer finds your 205W and you initiate the update, the plugin will install the new system to your unit.
Hope helps.
Apr 03, 2011 | Garmin nuvi 205W GPS Receiver
Yamaha Sound card
Hai,
Ds1.sys driver .sys information file is windows driver file.DriverUpdates will keep your system up to date by automatically getting the latest drivers from your hardware's manufacturer. No need to waste hours upon hours every week searching the Internet for the latest driver files.By having the most up to date device drivers on your system, your computer will run at optimal performance and be free of errors!
Try with http://www.driverguide.com/ to find out your suitable driver,by entering Device name/number.
Hope it Helped you,
Jestin.
Aug 05, 2009 | Computers & Internet
3,016 people viewed this tip
David Payne
David Payne
