Tip & How-To about Office Equipment & Supplies
How to reset HP Officejet 6310 printer.
this tip going to be a solution for most of the problem in
HP Officejet 6310 printer.i just makes you to reset your device in many levels.
power drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
partial reset:
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
semi full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
Full reset:
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
I have an HP Officejet 6310 All-in-One printer. I
Open the HP Photosmart Software on a Windows computer
1. Do one of the following:
– On the Windows desktop, double-click the HP Solution Center icon.
– In the system tray at the far right of the Windows taskbar, double-click the
HP Digital Imaging Monitor icon.
– On the taskbar, click Start, point to Programs or All Programs, select HP,
and then click HP Solution Center.
2. If you have more than one HP device installed, select the HP All-in-One tab.
Note On a Windows computer, the features available in the HP Solution
Center vary depending on the devices you have installed. The HP Solution
Center is customized to display icons associated with the selected device. If
the selected device is not equipped with a particular feature, then the icon for
that feature does not display in the HP Solution Center.
From here, you can scan, make copies, and perform maintenance procedures such as checking the ink levels for the print cartridges.
Nov 16, 2009 | HP Officejet 6310 All-In-One InkJet...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
Jan 31, 2009 | HP Officejet 6310 All-In-One InkJet...
My Officejet 6310xi All-in-one keeps going to power reset also. I went to hp.com and followed the recommended troubleshooting steps there. I also used the directions to reset the printer to factory settings and did the steps for power supply problems...no joy...
Hi. I just got off of the phone with an HP case manager. I was ready for a refund, but he helped me and now my printer is working fine. The key is to have your Officejet 6310 plugged directly into a wall socket. The variations of power through a surge protector often cause a power shortage to the unit. The 6310 needs the 110 volts to operate. Surge protectors will sometimes rob the unit of this power. Follow these steps:
1. Unplug the power cable & ethernet/usb cable from the unit (stand alone mode). Let it sit for a minute.
2. Plug the power cable directly into a wall socket. Then plug the power cable into the 6310.
3. After it powers up, push the "Setup" button.
4. Right arrow to "2.Print Report."
5. Press "OK" button.
6. Right arrow to "4.Self-Test Report."
7. Press "OK" button.
A page should print showing alignment and color settings. Now you're back in business!
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
836 people viewed this tip
k24674
jasbo
jasbo
