Tip & How-To about Computers & Internet
MultiBoot USB Flash - Survival Guide
Grub4DOS is a boot manager
that can be easily installed to a USB flash.
It allows booting multiple operating systems
from a simple graphical user interface.
1.) Format the USB flash drive in the FAT32 or NTFS filesystem. (Windows)
Download and start HPUSBFW.EXE )http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
-REMINDER!!! all data will be deleted on the USB flash-
1.a) Download necessary files
Grub4Doshttp://dl.dropbox.com/u/4040651/grub4dos-0.4.4.zip
Grub4Dos gui Installer 1.1
http://dl.dropbox.com/u/4040651/Grub4Dos%20gui%20Installer%201.1.rar
1.b) Extract the downloaded zip files into separate folders.
For example:
Grub4DOS to C:Grub4DOS
Grub4Dos gui Installer 1.1 to C:
2.)
If your flashdrive is not already plugged into the computer, plug it in now.
2.a) The next step is to run the Grub4DOS Installer.
Browse to the Installer's unzipped folder using Windows Explorer.
2.b) Run the grubinst_gui.exe program (Windows XP)
Right-click on grubinst_gui.exe Run as administrator (Windows 7)
2.c) Once the program is started, select the Disk option,
then click the Disk Refresh button and then select
your flashdrive from the dropdown box.
IMPORTANT:If you accidentally select the wrong drive,
you may not be able to boot your system without doing a boot repair.
2.d) Now click the Part List Refresh button,
then the dropdown box and finally select the Whole disk (MBR) option
2.e) Click the Install button to install Grub4DOS to the MBR
of the flashdrive.
Hopefully, you'll get the message that the installation was successful.
3.) The next step is to copy the grldr file to the flashdrive's
root folder.Using Windows Explorer, browse to the folder
where you unzipped
the Grub4DOS program and copy the file to the flashdrive.
3.a) Grub4DOS is now installed on the flashdrive.
4.)Download file
menu.lsthttp://dl.dropbox.com/u/4040651/menu.lst
4.a)You need to copy the menu.lst file to USB Flash
4.b)Create a folder Boot on a USB flash drive.
in this folder create new folders
Splash
menus
4.c) Download file
Snaiyahttp://dl.dropbox.com/u/4040651/Snaiya
4.d) On USB flash-open the folder Boot
Within-we see Splash folder. Copy the file Snaiya into it.
5.) Add Puppy Linux on a multiboot USB flash
5.a) Download the Puppy ISO imagehttp://www.puppylinux.org/
5.b) Create a folder Puppy on a USB flash drive.
5.c) Take from the downloaded ISO, file
PUP_420.SFS (from the folder Puppy)
Rename it to pup_420.sfs
and copy it to
USB flash.
5.d) Copy all other files from the downloaded ISO (from the folder Puppy)
to the folder /Boot/Puppy/ (Create a folder on a USB flash)
5.e) In the menu.lst add a:
title Puppy
kernel (hd0,0)/boot/Puppy/vmlinuz ramdisk_size=100000
initrd /boot/Puppy/initrd.gz
5.f) Preserve the changes and now menu.lst looks like this:
gfxmenu (hd0,0)/boot/Splash/Snaiya
timeout 30
default 0
title Puppy
title Boot from CD-rom
cdrom --init
map --hook
chainloader (cd0)
title ShutDown PC
halt
title Reboot PC
reboot
5.g) Puppy on our MultibootUSB flash-is ready for operation.
(Now we can restart our computer and see how it looks and works)
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
Computers & Internet Logo
How do I reboot if it wont restart.
You can boot it up with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB Flash Drive and boot up Operating System from bootable CD/DVD/USB Flash Drive directly.You can use it to retrieve data under any boot up problem.Get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Aug 04, 2011 | Gateway GT5694 Desktop Computer
INSTALLATION
I don't think this is possible. Still we can work on this.
Even I am verymuch Intersted with these kind of issues. I haven't tried installing XP on USB flash drive. But I installed the XP on USB harddrive and it worked.
We can try this with your co-operation. To boot with the USB devices, first your computer or laptop should have the option to boot with the USB devices. You can check in BIOS, under BOOT order for this option.
If USB boot option is not there, then you cannot boot with the Flash drive, not only flash drive all USB devices. They will work only after booting into Windows.
Comming to installation procedure, installtion is same as installing the XP on harddrive. While installing the XP, at partition page, you can see the USB flash drive, select it and continue the installtion.
If your computer has the option to boot with the USB devices and if the flash drive won't boot into Windows after installtion, then we have to set Flash drive as Active partition from Disk Management, and then we can try. In Disk Management, right click on the USB drive and select set active partition. If it won't allow to set the USb flash drive as active, then it is not possible to install XP on flash drive.
Even I googled everywhere on how to do this, but not information.
Try that and let me know the status. But I am sure, it is possible on Pocket drivers or USB harddrives.
Aug 09, 2008 | Computers & Internet
6,990 people viewed this tip
David Payne
David Payne
