Tip & How-To about Refrigerators
Freezer working but no cool in Fridge/No Ice making
This is one of the common problem throughout the world. It's because of not going through User Manual before using the fridge.
To get better cooling, dispensing water, ice cubes from your refrigerator, please follow the steps.
1. Keep temp setting between 3 degree and 5 degree Centigrade.
2. Ensure, freezer door and mail door of Refrigerator are closed properly.
3. Check freezer fan is working. If struck by frosting behind the freezer, you have to defrost it.
4. Defrost cycling is not functioning properly. Because your set temp is less than 3 degree or in minus.
5. Auto defrost cycle not activated due to thermostat, timer, heater malfunction.
First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it
6. Check water line to make ice are not tint or remove kinks in water source line in the back of refrigerator to increase water pressure.
7. Check solenoid valve in the rear side of refrigerator back is activated.
8. If solenoid activated,no water flow means, have to clean solenoid valve.
9. Check shut off arm is not struck due to over ice stores in the ice bucket. Remove it.
Refrigerators Logo
domitec fridge will not cool
Have you tried it on electric?
If the fridge is level, and the rear coils of the fridge are warm and the fridge does not cool, you will more then likely require a cooling unit. Arcticold refrigeration manufactures brand new replacement cooling units that are available throughout north america Visit ArctiCold Refrigeration We keep it cold
Feb 16, 2014 | Dometic Refrigerators
What is a thermoelectric wine cooling system?
Thermoelectric cooling is best used in small wine coolers. Small fans from inside the cooling fridge evenly dispense cool temperatures throughout the interior of the unit.
Jul 31, 2012 | Furniture
directions to program cm 67 thermostat
How do I set one temperature for the whole day?
To operate as a simple thermostat with one temperature throughout the day, move the slider to the MANual position. Adjust the manual temperature by pressing the TEMPerature or button. The manual temperature can be set anywhere from 5°C to 30°C in 0.5°C steps.
Here is the User Guide for the CM67 Thermostat:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
May 17, 2011 | Honeywell Heat/Cool Thermostat
my maytag refigerator is not cool but the freezer is ice cold.
Is has something to do with the flow of air from the freezer compartment into the fridge department. First make sure the thermostat on the fridge side is set to colder, then check out for obstructions in the air passage ways, you may have to remove your food for a better view. One's at the top, one is at the bottom. the other thing, try to find out if the fan within the freezer is running as it's supposed to, since it's what takes care of circulating the air throughout the fridge. One common source of blockage is accumulated ice in the freezer side which blocks off the opening into the fridge side. The openings are meant to stay clear.
Jul 31, 2009 | Refrigerators
Refrigerator is barely cooling, but freezer woks fine.
Sounds like a defrost problem. First though, check your settings that they are in the correct spots where the owner's manual tells you they should be. IF that is not the issue, next, can you look in the area of the back wall of the fridge to see if the condensor coils are all iced over? You may need to remove the rear inside panel to see them. No hard, couple of screws and your there. This is most commonly caused from little people or our beloved spouse (never us!) leaving the fridge door open a smidge overnight or through the day. Another common problem is after the holidays when someone other than yourself tries to stuff the 50 pound turkey in a 20 spot leaving no room for the door to shut. As a result, the chilling function will go into hyperdrive to keep cooling and eventually ice over and become very inefficient at cooling in the fridge. Even the freezer is effected, but it is not as easy to notice. Here's what to do. Once you find the large area along the back wall of the fridge that contains the frozen over coils, you will want to unplug the fridge and get that ice out of there completely. Using hot water and a catch basin to catch the water you pour over the coils, continue this until the ice is all gone. Make sure your settings are back to normal settings as per owner's manual and plug in. Should be all better now.
Jan 07, 2009 | Kenmore Refrigerators
596 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
