Tip & How-To about Cannon i70 Printer
How to resolve Cannon ir400 Error e004
For error code E004-001 or E004-002
Cause:
The SSR has a short circuit.
• The SSR has an error.
• The DC controller PCB has a fault.
The heater relay has an error.
• The heater relay has an error.
Description:
• The fixing heater remains
on.
• The fixing temperature has
increased abnormally.
The heater relay remains on.
FIRST TRY TO CLEAR ERROR:
Resetting Errors
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
SERVICE MODE:
1) Press the asterisk key ' * ' on the control panel.
2) Press '2' and '8' on the keypad at the same time.
3) Press the asterisk key ' * ' on the control panel.
If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.
Hope that helps!
canon ir5000. How do I correct error 732?
These are all list of error code in Canon iR5000/iR6000 more to come, i hope your machines works fine and never get error.
  • E000
Main cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
  • E001
Main cause: The main thermistor (TH1) has a short circuit.The sub thermistor (TH2) has detected overheating.The SSR is faulty.The DC controller PCB is faulty.Mode of detection:0001 The main thermistor or the sub thermistor has detected about 230?C or higher for 2 sec.0002 The main thermistor has detected 230?C or higher (hard circuit detection)0003 The sub thermistor has detected about 236?C or higher. Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
Jun 02, 2015 | Office Equipment & Supplies
how to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
Description
I would suggest calling the copier repair personal.
Feb 21, 2014 | Canon imageRUNNER 400S Copier
Canon ir5075 error code E00014-000
ese are all list of error code in Canon iR5075
  • n cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
  • E001
Dec 12, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
how to clear e004 for ir3170
The SSR has a short circuit.The DC controller PCB is faulty.The SSR used to drive the fixing heater is found to have a short circuit.The error must be reset in service mode COPIER - FUNCTION - CLEAR - ERR.
Feb 21, 2013 | Canon imageRUNNER C3170I Color Copier
Canon ir 2220 ERROR CODE E261
U NEED TO INVESTIGATE
the input/output ports of the DC controller PCBs.
COPIER>I/O>DC-CON<DC-CON (5/7)>
P020 xxxxxxxxxxxxxxxx=runs from left to right 15>0
ADDRESS=P020
BIT-
0- zero-cross signal -
1- heater trigger 1 signal 0: ON
2- heater trigger 2 signal 0: ON
3- heater error OFF signal 0: error
4- not used
5- not used
6- M9 registration motor phase A pulse signal -
7- M9 registration motor phase B pulse signal -
E261 0000
The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected?
(zero-cross signal: J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Jan 22, 2013 | Office Equipment & Supplies
1,106 people viewed this tip
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
