Tip & How-To about Computers & Internet
DIY Manual PC Tune-Up
Is your computer running slow? Are you experiencing lags watching streaming videos? Do you experience popup error messages every now and then? Then, your computer might be in need of a tune-up !
There are a lot of free pc tune up softwares that can be downloaded from the World Wide Web or the Internet but you never know what they automatically do on your computer. The best still is a manual pc tune up for your computer so that still, you have full control on what's coming in, going out and what's being deleted.
Benefits
I don't see any disadvantages in performing pc tune ups. It's like having your car maintained for an oil change. In short, PC Tune Up is part of maintaining your machine as a painter cleans his brushes and palette after he finishes his "Obra".
PC Tune-ups can prevent virus infections that your antivirus software does not recognized yet. It also optimizes the performance of both your PC and Internet connection. In some cases, it can resolve a "page cannot be displayed" error messages. It helps you save time and money from loosing your memories and work files, for having it serviced for a wrong reason and a lot more that may result to stress and annoyance. So, without further adieu, let's start maintaining your computer.
Manual PC Tune-Up
I. Files and Programs
First step is the number one rule you might want to always remember when performing maintenance on your computer: BACK UP your important files. You may use all sorts of media (CDR, DVDR, usb flash/hard drive, etc) but never in a hard drive partition that you use with your computer.
Second, REMOVE/DELETE UNUSED FILES/PROGRAMS. As you have backed up your important files, delete files that has been idle for quite sometime. Emty Recycle Bin and uninstall all programs as well that has been idled, toolbars that crops you internet browsing and the likes.
NOTE: Leave only the active files and programs that you regularly use.
Now, let's perform a disk clean up.
Click "start" > Open "My Computer/Computer" > Right click "C:" > Click on "Disk Cleanup" button > Tick all empy boxes > Hit "ok" button.
Then, reset internet option settings.
Click "start" > Open "Control Panel" > Switch to "Classic View/Small Icons" > Launch "Internet Options" > Delete Temporary Internet Files (may vary on Windows version) from "General" tab > Click on "Security" button > reset all zones (internet, intranet, trusted sites and restricted sites) to its default settings > Click on "Content" tab > Click on "Clear SSL State" > Click on "ok" button > Click on "Connections" tab > Click on "LAN Settings" button > make sure nothing is ticked on all 4 boxes > Click on "ok" button > Click on "Advanced" tab > Click on "Restore advanced settings" > Click on "ok" button.
Lastly, let's clear all the cobwebs.
· Press [windows key]+[R] > Type "temp" > Hit "ok" button > Press "Ctrl"+"A" > Press "Shift"+"Delete" > Press "ok" button.
· Press [windows key]+[R] > Type "%temp%" > Hit "ok" button > Press "Ctrl"+"A" > Press "Shift"+"Delete" > Press "ok" button.
· Press [windows key]+[R] > Type "prefetch" > Hit "ok" button > Press "Ctrl"+"A" > Press "Shift"+"Delete" > Press "ok" button.
NOTE: Do not mind files that aren't allowing you to delete. You may leave them as it is.
II. Windows Registry
You may use any free windows registry cleaner that you can download, install and run on your computer, off from the internet. The most popular registry cleaner program, as of today, is CCleaner (free version). But if you find CCleaner is too confusing or technical for you, I suggest you use either Wise registry cleaner or Comodo system cleaner. Compare and pick only one program. I recommend for you to uninstall them after use.
III. Hardware
Dust, cobwebs, and worse loose screws that might create a short circuit inside your Desktop. For laptops, nothing much to do but to wipe surface with an anti-static cloth to clean them. De-static your body first by holding to an unpainted metal for about 30 seconds. Remove side cover panel of your desktop and if you find any of these dirt in you computer, tighten up gently or replace screws then use an anti-static electronic equipment aerosol spray to blow away all obstructions. Reseat cables if and when necessary. Place back side cover.
Perform manual pc tuneup every after 3 to 6 months depending on the loads of work you do on your computer. Enjoy!
NOTE: This is not a fix for virus infection issues.
Thank you for using Fixya!
Mongkey
"Understanding explains better..."
Computers & Internet Logo
keep getting a box popping up talking about script errors. how do we stop that?
If you use Internet Explorer as your Web browser, chances are you have experienced, or will experience, popup script errors. Typically, a dialog box may appear stating "A Runtime Error has occurred. Do you wish to Debug?" or "Internet Explorer Script Error. An error has occurred in the script on line 1. Do you wish to continue running scripts on this page?" These errors can be distracting and interfere with your Web browsing experience. If you would like to stop receiving these error messages, you must modify your IE settings.
Open IE, select "Tools" and ten choose "Internet Options." The Internet Options dialog box will open. Click on the "Advanced" tab, scroll to the "Browsing" section and then select the "Disable Script Debugging" box.
Clear the "Display a notification about every script error" box under the same section if it has been selected. Click "Apply" and then choose "OK" to modify your IE settings. You will receive no more IE script error notifications. Hope this helps.
Jan 01, 2013 | Microsoft Internet Explorer 8
unable to watch you tube videos
Start from repairing your Windows registry and fixing your Windows errors that become the cause of many browser and applications errors causing a conflict situation.
* Test your computer for viruses and spyware.
* Run SpeedTest to test whether you have sufficient bandwidth available to smoothly play YouTube videos without causing the site to run slower.
* Disconnect your internet and then reconnect it to know why is YouTube slow and whether it is because of the poor internet at your side.
* Disable ads through some of the browser plug in that will allow you to run fewer background services while you are playing videos online.
* Try to change your flash player version. Although the YouTube has started to stream videos through a new technology there is still a large number of web sites using the flash platform. So it is a nice idea to try to change the flash player version to play videos without crashes and error messages.
* Try to change your browser. One good browser to play YouTube videos is Chrome. If you have not tried that go for it. Also contact your ISP provider if they are limiting your bandwidth at specific durations of the day.
The above solutions will most likely fix and answer your question why is YouTube slow on your computer. However, it is highly recommended you follow all the guidelines especially optimizing your PC Windows for internal registry errors through a top registry cleaner reginout
Feb 06, 2011 | YouTube Videos
computer lags when playing games
You really need more Ram. But if that's not an option, then open "Activity Monitor" under Utilities folder in Apps folder. Go to User Processes, and you can see exactly what's taking up your Ram and slowing your game. Quit each process and hope for the best. Don't fool with the System Processes section; you might quit a process that is essential to running your computer.
Apr 06, 2010 | Computers & Internet
slow video, lags behind audio
You didn't include any specs on your computer but most of the time this is an issue that might be helped by maxing out the memory in your pc. However check your pc to see how much memory it has and then check the specs on your pc to see how much memory the BIOS will recognise, but keep in mind that sometimes if you're broadcasting video thru the internet you are at the mercy of the data stream on the net. Sometimes when traffic is heavy at some sites the video will lag and there is no solution.
Apr 12, 2009 | Computers & Internet
Video streaming that constantly buffers
At&t offers 4 speeds to its customers, 768 kbps 1.5 mbps, 3.0 mbps & 6.0 mbps.  On the 1.5 connection depending on what type of video you're watching, you will experience some glitching.  If your general internet seems slow, then scan for malware/spyware.
I reccomend you use malwarebytes free version doesn't give realtime protection
Apr 09, 2009 | Microsoft Windows Vista Home Premium...
5,119 people viewed this tip
Alun Cox
