Tip & How-To about Microsoft Windows Server Standard 2003 for PC
Creating users easily and quickly in windows xp
Creating users in windows xp:
Go to start, then run, type "cmd".
Here, you can type the following command to create a user,
net user "username" /add "password"
net user "username" /del "password"
example:
net user goodmorning /add *****
And also you can manage your user accounts in the user management option:
Right click the my computer icon in desktop, click "manage".
Here you can find "Local users and groups". you can create, remove,manage the users, and groups here also.
Microsoft Windows Server Standard 2003 for PC Logo
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
Nov 10, 2013 | Computers & Internet
how can i recover my administrator password on windows xp if i forgot it
You could do the following; when you boot up, the screen will tell you to press ENTER if you want to get into the operating system RESTORE MODE. When you set up your system you will have saved configuration settings, and hopefully, you would have carried out a number of saved "BackUp's" of your HardDrive as you used your computer. If you did, you can carry out a 'Go Back To A Previous Setting'. You will lose any files you created since that previous time but it does get you back into your drive. Did you not create an Administrators Password BackUp Disc? If you did use that. Good Luck. George
Mar 31, 2013 | Dell Dimension 4600 PC Desktop
i have changed a new password for my administrator account and foget the password, i can only log through the user account. pls help me with steps on how to reset the password and enter new one
Do you need to reset vista or xp users password? Ihas a little trick that dig it for you from tech-hack forums. The method is very easy to follow and doesn't require any complicated commands. The method is free to use and you don't need to pay hundreds of dollars for some utility for unlocking lost windows passwords. Just follow next simple steps:
First thing you need to do is to start command prompt or CMD. There is two ways to do that:
Press F8 when Windows XP start up (before windows xp logo - progress bar for loading) and choose "Save Mode Command prompt" option
If you are logged in: click on start -> Run, type "cmd" and press ENTER.
In command prompt window type command "net user" or "net users". You will see the list of users that are created on current running OS.
Type "net user" "user name" "*". You will see that windows will ask you to enter new password for that particular user account! No super user privileges needed. Just type new password two times and you are done.
Example of process: If the administrator username is "administrator" then command for changing its password will be: "net user administrator *".
Note: quotes (") in the post are just for highlighting the word.
Nov 02, 2009 | Microsoft Windows Vista Ultimate Edition
315 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
