Tip & How-To about Google Android
Take screenshot of Android phone.
You can take screenshot of android phones when conencted to a computer.
To take a screenshot you need to download the Android SDK for your machine. It includes a tool called ddms which is the dalvic debug monitor. Dalvic is the Java runtime powering all the apps on your android phone.
Connect the phone to your machine, run ddms from the terminal and go to Device > Screen Capture (or Ctrl-S) for taking a screenshot.
Google Android Logo
Capturing and sending a screenshot on my android
Well friends it is very simple to do so. However for answering your question which brand of phone you are using. In most of the android phones, screenshot is taken by pressing power and volume button at the same time. On the other hand in Asus, all you need to long press the back button...So, now you can share android games score or any photo you share on android apps easily with just one click. Android Games for pc Archives Apps PC Store Download Android Apps For PC
Aug 02, 2017 | Android Cell Phones
how do i take a screen shot on a motorola droid 3
The Motorola DROID 3 runs on Android and as of now, no applications are available that allow for on-device screenshots. This guide will provide you with the software you need and show you how to get stunning screen captures from your device.
Two separate pieces of software are required and must be installed on your PC:
  1. The Android software development kit (SDK)
  2. The Java SE software development kit (SDK)
Once your downloads are complete a few steps are required to get things ready.
On your computer:
  1. Extract the Google Android SDK to a folder on your desktop
  2. Install the the Java SE SDK
On the Motorola DROID 3:
  1. Press the Home icon, press Menu and then tap Settings
  2. Tap on Applications
  3. Tap on Development
  4. Check the box for USB debugging
Now you are ready to get started.
  1. Plug your Motorola DROID 3 into your computer via USB and Windows will attempt to install all of the appropriate drivers; one of the drivers will not be found and thus you must proceed to Device Manager in your Control Panel and find the Motorola DROID 3 (there will be a yellow icon next to it)
  2. Right-click on the Motorola DROID 3 entry and select properties; instruct Windows to update/install the driver for this device and when asked, simply browse to the usb_driver folder inside of the Android software development kit folder that you extracted to your desktop earlier -- the device is recognized and the driver is installed
  3. Browse to the Android SDK folder that you extracted to your desktop and run the SDK Setup.exe to start the program
  4. Once the application has launched you will be presented with a window as shown in figure 2 above
  5. Click on the Refresh button so that the application can update its list of operating system SDKs available from Google
  6. Check off the section next to the URL that is shown in the application; you are now presented with a list of Android SDKs and Google APIs you wish to install
  7. It is recommended that you select select all available packages for maximum compatibility
  8. Once the files have been downloaded simply close the application
  9. Browse to the Tools folder inside the Android SDK folder you extracted to your desktop
  10. Double click on DDMS.BAT to execute the Dalvik Debug Monitor
  11. The application will launch with a DOS command window and eventually a Windows based application -- your phone will be listed on the left hand side, and you should click on it to make sure it is selected
  12. Click on the Device menu and select Screen Capture or use the CTRL-S key combo
  13. The capture now appears on your screen, but there is one final undocumented step
  14. We recommend that you click on the Copy button and paste the screenshot into your image editor of choice (Microsoft Paint, Adobe Photoshop, etc) -- the reason for this is that there is a known bug that does not carry over the colors of the actual screenshot inside the capture utility
Voila! You now have a stunning screenshot from the display on your Motorola DROID 3. Repeat steps 12-14 to generate more screenshots.
May 02, 2014 | Motorola Cell Phones
which site i will get the android operating system to download?
If you're looking to download the operating system itself, try here: http://source.android.com/source/download.html
If you wish to develop for android, you'll want to get the SDK which is available here:http://developer.android.com/sdk/index.html
Feb 28, 2011 | Computers & Internet
333 people viewed this tip
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
