Tip & How-To about Acer Aspire 5500 5570-2609 Laptop
How to Fix an Acer Laptop Keyboard Key
  1. Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop.
  2. Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole.
  3. Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.
  4. Set the key back onto the plastic clip. Push the key down until it clicks into place.
  5. Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen.
  6. Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop.
  7. Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air.
  8. Reassemble the keyboard, LED indicator strip and battery.
If I could be of further assistance, let me know.
Thanks,
LETMEFIXIT
Acer Aspire 5500 5570-2609 Laptop Logo
WHen using the shift key to type the at sign or the esclamation mark etc it does numbers
Is this the only problem with the keyboard not getting uppercase to work ?
While Acer laptops are built to be used on the go, they are not indestructible. An accidental drop or even normal wear and tear over an extended period of time can cause the laptop keys to become dislodged and fall out. Debris can also build up inside the keys and make them stick or stop working. Fixing the keys on your Acer laptop is a quick process that does not require taking the unit to a professional repair shop.
Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop. Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole. Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole. Set the key back onto the plastic clip. Push the key down until it clicks into place. Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen. Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop. Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air. Reassemble the keyboard, LED indicator strip and battery.
Acer aspire keyboard removal http://www.cyfinity.com/2008/07/acer-aspire-5315-keyboard-removal/
Mar 01, 2013 | Acer Aspire Computers & Internet
keys 5, 6, r, t, f, g, v don't work on Aspire 4720z. What should I do?
1.Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop.
2.Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole.
3Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.
4.Set the key back onto the plastic clip. Push the key down until it clicks into place.
5.Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen.
6.Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop.
7.Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air.
8.Reassemble the keyboard, LED indicator strip and battery.
Sep 28, 2011 | Acer Aspire 4520-5582 Notebook
keyboard does not work at all.
3.Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.
Sep 07, 2011 | Acer Computers & Internet
I dont know how to take off the battery
If it is a laptop battery you will need to flip it over and there will be a release switch / lever. You will need to slide the lever to activate the release. This will usually pop up the battery, but if not then slide the release and there should be a way to pry up the battery. Hope this helps.
Jul 29, 2009 | Computers & Internet
I want to open my acer aspire 5050 to fix my problem but I couldnot inspite of taking out all screw from bottom and behind the laptop. Any advise with or without pictures is appreciated. Thanks sa
Removed the cover along the top (Where the power buttons is) by removing the three screws along the back of the laptop. You need to be careful removing this as it has small plastic clips that are very easily snapped. Once that’s off you can remove the two screws that hold the Keyboard in place. Lift the keyboard and release the catch on the Keyboard cable on the motherboard. Allows you to lift the keyboard away.
With the keyboard removed, remove the screw that’s holding the CD/DVD drive in place and slide the drive out (the release for the battery on the underside sometimes catches the drive too, so if its sticking just slide the battery release over)
Then remove the cable for the LCD display and pull the wireless connection cable through the hole, Remove the screws holding the Display in place and remove completely.
Remove the 2 screws holding in the Power button board and lift it off.
Carefully remove the 2 cables for the Touchpad, Being careful with the ribbon cable it’s again it’s easy to destroy these types of cable.
Flip the laptop over and remove all the screws from the underside, this will make it seem like its ready to come apart, but it’s not. Flip it back over and remove the top. Next to the connector where the battery plugs in you’ll find one final screw to remove. Now on the back of the laptop you’ll find your VGA port, remove the two nuts on this (long nosed pliers do this job easily or a small socket if you have one that small) once these are removed lift the motherboard from the front side of the laptop and slide it out, you now have your motherboard out.
Please rate this a fixya
Feb 19, 2009 | Acer Aspire 5050-3242 Notebook
4,518 people viewed this tip
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
