Tip & How-To about Video Game Consoles & Games
How to connect your Wii to the internet Wirelessly
Hi Everyone,
If you want to connect you Wii to the internet wirelessly first we need to know the settings of your router. Listed below are the steps on how to access your router. You need a working computer connected to the router to access it follwed by the steps on how to connect our Wii.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we have the information needed lets connect your Wii to the internet.
1. Select Wii Settings
2. Then Internet Connection Settings
3. Search for an AP or SSID
4. Input Security Key or Network Key
5. Test the Connection.
Other Suggestion
Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii and test for proper response.
The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to. If it is different
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
Thanks for using Fixya.
Video Game Consoles & Games Logo
How to get internet wii wireless
Welcome to Fixya. If you want to connect you Wii to the internet wirelessly first we need to know the settings of your router. Listed below are the steps on how to access your router. You need a working computer connected to the router to access it follwed by the steps on how to connect our Wii.
Other Suggestion
Jun 25, 2011 | Nintendo Wii Console
Unable to connect wirelessly
i had the same problem. i took and reset my wii by unplugging it for 30 minutes . the i opened my wireless internet up before i turned it back on. when you turn your wii back on go to the system setup and it will give you a step by step were you have to enter a password if you have a wep code set on your wireless router.
Mar 03, 2011 | Nintendo Wii Console
My Wii will not connect to my router. I have tried all the routerlogin.net and .com solution attempts. Also the 192.168.1.1 stuff. No luck. Netgear tells me I have to use their support tech at $69.995. No way! Anyone out there can help me?
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Other Suggestion
Don't forget to say thanks. Thanks for using Fixya
Feb 22, 2011 | NetGear WNR1000 Router
How do I hook my Wii Console to the internet? I have a wireless router
Feb 06, 2011 | Nintendo Wii Console
Okay I enter my wifi password and stuff and when it is trying to connect it says.. Unable to connect to the Internet. Choose Internet setting and then confirm your connection. How do I do that?
Hi laurennajar,
Feb 05, 2011 | Nintendo Wii Console
848 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
