Tip & How-To about Car Audio & Video
How to set the clock clarion dxz365mp
Press and hold "D" button, search for "clock" using the track/channel up or down buttons on left of volume control, press "play/pause" button. and you got it from there.
Car Audio & Video Logo
Jvc kd-r210...how do i set the clock
Turn on the power, Hold the SEL button until you see DEMO ON. Use the track search buttons until you see "CLOCK H" turn the volume control to adjust the hours. press the track search to see CLOCK M and then adjust using the volume control. Press select to exit.
May 24, 2014 | Car Audio & Video
new truck with Jvc KD G230 How do I set the time
Hold down the Sel button for a second to enter the menu. (Sel is located just under the CD slot, slightly to the left) Then use the track forward, track back buttons to select either "Clock H" or "Clock M" Change those values by twisting the volume control knob when they are flashing. Press sel button again to save and exit. Cheers, Dan
Apr 29, 2011 | JVC Car Audio & Video
manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is set..now for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Oct 22, 2009 | 1994 Ford Tempo
demo problem
Here is how to shut off the demo:
1) Press and hold the SEL button for several second until DEMO appears on the display. Release your finger from the SEL button.
2) Using the Volume control knob, turn left or right to turn on/off DEMO.
3) Press and release the SEL button to accept.
Setting the clock:
1) Press and hold the SEL button for several seconds until the DEMO shows on the display.
2) Use the right search arrow in the 4-way button just above the SEL to get to the clock hour. Do not use the up or down key.
3) Turn the volume control knob to select the hour.
4) press the right arrow once more to get to the clock minute.
5) Turn the volume control knob to select the minute.
6) When finish, press and release the SEL to accept.
Good luck
Sep 02, 2007 | JVC KD-G230 CD Player
1,567 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
