Tip & How-To about Cell Phones
How to get your SECURITY or LOCKED code in your NOKIA phone
I want to share this tip on how to remove password or security code in your nokia phone..here is
the tool that you needed..
A.USB cable for phone like 3110c ,6300 ,3500c and the likes having big usb
B.MICRO USB UART for phone having small usb connection like e63 ,c3 ,7210c ,5130c etc...
first you need to download this software including the latest nokia_Connectivity_cable_driver_v7.1.36.0...
NOKIA SERVICE TOOL 1.0
http://www.advance-box.com/Angel/NokiaServiceTool_v1.0.rar
NET framework 4 ../en/details.aspx?FamilyId=8E011506-6307-445B-B950-215DEF45DDD8&displaylang=en
procedure..
1.open Nokia service tool 1.0
2.tick usb mode
3.then read user code
http://www.advance-box.com/Angel/Phone_Info.JPG
4.you may smile now because you get your security code..
http://www.advance-box.com/Angel/service_options.JPG
NOTE..it will not work if the Network frame 4 is not installed...
i hope it will help you getting your forgotten code ,thanks for trusting fixya...
Cell Phones Logo
I want to remove my security code but i forgot.. Pls tell me how this my imei 358653014386753 .. Thnks
If your phone didn't prompt you to enter security code during start up..here is the solution..First you need to collect is Nokia Usb cable which is supported to your phone.Now follow this link to generate the current code How to Generate Your Phone Security code..Only for Nokia bb5.With the generated code you can easily change/remove the security code.Good luck
Jul 13, 2012 | Nokia 5130 Cellular Phone
I have given security keyguard password to my phone. But I want to change the password...Pls. Help Warm Regards, Bhavesh
I thought that you could not remember the current security code.....which you have made.No problem you can change but first you should the current code.So, to get the code follow this How to Generate Your Phone Security code..Only for Nokia bb5. First thing you need to collect is Nokia USB cable and download Ant Simple.zip.Generate the code and reset ,,,,Good luck.Thanks for visiting fixya
Jun 27, 2012 | Nokia Classic 2700 Cell Phone
i forget my security coad
security code is need to protect our phone to other people who sometimes used our phone...we put code to so that the important and confidential message is not viewed by others..but there is a time that we forget it ,and going to a mobile phone shop to read our security or locked is means that we are spending money...there is a way to read your nokia code by means of calculating it in master code but that is for dct3 and dct4 kind of cellphone...bb5 and sl3 kind of phone like 7210c ,5130c .c3 ,e63 and any kind of high end phone is not supported by any master code unlocker online..so what will you do to read your code without losing even a single bytes of your files,and not spending even a single amount of money in a mobile repair shop?
i want to share this tip on how to remove password or security code in your nokia phone..here is
A.USB cable for phone like 3110c ,6300 ,3500c and the likes having big usb.....
NET framework 4 ...http://www.microsoft.com/downloads/en/details.aspx?FamilyId=8E011506-6307-445B-B950-215DEF45DDD8&displaylang=en
procedure..
2.tick usb mode
Feb 12, 2011 | Nokia 3110 Cellular Phone
nokia 6600 phone lock forgot password how can i recover password
for the recovery of your password you may consult a technician near you.. they have the right fLasher tooLs and cables for your phone they will be able to see those codes which is being saved to your mobile using those flasher tools and cables... if you haven't changed your security code the default code is 12345 but if you really have to use it... I have a solution for that.. you may reformat your phone...
here is the procedurea:
remove the sim card then switch on the phone
and press and hold the following
* 3 the green key(which is the shortcut key for a call) and the switch off button
just hoLd the 4 button untiL the word reformatting comes out of your screen if it is done your phone codes are backed to your deafult codes which is 12345
hope it works.... :) don't forget to rate my solutions my friend
Aug 16, 2010 | Nokia 6600
153 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
