Tip & How-To about HEWLETT-PACKARD Hewlett Packard 53A LaserJet M2727 MFP, P2014, P2015 Series Smart Print Cartridge (3,000 Yield)
What is a Scanner Error 5 Hewlett Packard M1522nf
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M1522
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
Contact Hewlett Packard for possible Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
HEWLETT-PACKARD Hewlett Packard 53A LaserJet M2727 MFP, P2014, P2015 Series Smart Print Cartridge (3,000 Yield) Logo
canner Error 52 Hewlett Packard M1522nf
Please try the below listed steps that should resolve the issue.
  1. While the printer is ON, unplug the power cord from back of the printer.
  2. Also unplug any other cables connected to it. ( USB / Telephone, LAN cable etc )
  3. Wait for 3 minutes.
  4. Plug in the Printer Power Cord directly to wall outlet and then to the printer.
  5. Printer should power ON automatically, else press the ON button to do so.
  6. Now try making a Copy. It should work.
  7. After which connect all the cables / cords that were unplugged.
Jun 24, 2014 | HEWLETT-PACKARD Hewlett Packard 53A...
HP-2727mfp scanner error problem
HPM2727mfp - Scanner Error 5 - Scanner Error 8
These errors indicate a problem with the flatbed scanner assembly. The flatbed is no longer able to initialize or find home position. The scanner may move back and forth continually and the light flicker at a high rate of speed. The flatbed scanner will need to be serviced/changed. The part required is CB532-67905
M2727SCANNER
Please contact your local Hewlett Packard Repair Center.
HPPARTNERLOCATOR
Jan 02, 2011 | HP Laserjet M2727nf Multifunction Printer
HP M1522 MFP does not start up...it says Hewlett Packard >>>> ....and is stuck here....wat to do??
Hi ronrod123,
This is a problem with the formatter board, Hp has issued a service note, call their tech support line and request a case number to have the printer serviced at a local asp.
Al hp's tech 1800 334 5144
Sep 28, 2010 | HP LaserJet M1522nf Multifunction Printer...
5,025 people viewed this tip
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
