Tip & How-To about Video Game Consoles & Games
How to connect your PS3 to the internet wirelessly
Before we connect the PS3 console to the internet we must be familiar with the settings of the router. Listed below are the steps on how to access the router and how to connect the console to the internet wirelessly.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remember the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Steps on Connecting PS3
1. Power-cycle ALL network equipment. Turn off (unplug) ALL of your network equipment, including any Wireless Access Points, Routers, Voice Over IP (VOIP) Modems, and Broadband Modems for two (2) full minutes.
2. Confirm that your internet connection is enabled. in the home menu, go to Settings > Network Settings > Internet Connection and select Enabled.
3. Scroll down to Internet Connection Settings and When prompted, "Do you want to continue?" select Yes. On the next screen, select Wireless as your connection method. Pick "Scan"
4. From the list, pick your SSID.
5.On the next screen, press right on the directional pad to continue
6. Pick your WLAN Security Setting (either WEP or WPA-PSK/WPA2-PSK). If none, pick None (and skip the next step).
7. If you selected a Security Setting, enter your Security Key or Network Key with the keyboard. Press the Start button to exit the onscreen keyboard. Press right on the directional pad to proceed to the next screen.
8. The system will check your network configuration settings and display the information. Save the Settings.
9. Test the connection on the next screen.
10. When the test is complete (usually less than a minute), it will display the results ("Succeeded" or "Failed"). If you have successfully connected to your network, Congratulations, you have completed the network setup process.
Video Game Consoles & Games Logo
im trying to set my ps3 to wireless network
Welcome to Fixya. Before we connect the PS3 console to the internet we must be familiar with the settings of the router. Listed below are the steps on how to access the router and how to connect the console to the internet wirelessly.
If you have questions please let me know. Thanks for using Fixya.
Apr 21, 2011 | Video Game Consoles & Games
hi trying to set up wifi but keeps coming up with ssid and wep
Apr 09, 2011 | Sony Playstation 3 (PS3) Console
What do I need to connect the PS3 to the internet so my boys can play online ? Hardline or will WIFI work ?
Any of the two will work it all depends on preference. If the modem or router is too far from the console then you would most likely want to go wireless. Here are instructions how to do each:
WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
error 80010514
Hi joe,
Here's a guide on how to fix your problem. Click here.
And heres a guide on how to connect your Ps3 online.
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
don t know wpa and no button on router so is there any way to establish a conection to the network.
2. Confirm that your internet connection is enabled. In the home menu, go to Settings > Network Settings > Internet Connection and select Enabled.
Don't forget to say Thanks.
Feb 06, 2011 | Sony Playstation 3 (PS3) Console
639 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
