Tip & How-To about Computers & Internet
Tips to Fix Computer Speakers
Computer speakers as the most important accessories for any type of computer. Therefore, people mainly buy it on your computer. But it is quite difficult to make a good service to the speakers, because they are not made to withstand heavy bass and, therefore, tend to break easily after some time. So, some time after its use, the task is ready to strengthen it.
There are two ways to fix a speaker, including - Do it yourself or hire someone to do it. But the routes remain the same.
There are highly effective steps to take to fix, including - the first thing I see is that if the speaker is under warranty or not, then just give the company and the repair mechanic there.
And if it is not under warranty, then it's essential steps to follow:
Inspection of the horn: To examine all aspects of the speaker to locate the exact problem. Check with the sound generated by the speakers. Also check if the problem comes from the speakers or equipment. If this is not one of them, make sure your computer and speakers are properly connected and the powerful. And if not, they connect to a different location. On the other hand if you use the tape, so it is best to replace it.
So if the speaker is on and use a USB cable to power then check the connection between the USB cable and a USB port on your computer.
When you see that you have the power to the speakers, good sound control and if you still do not have sound so it becomes necessary to check the speaker cable to the computer is plugged into the green audio output on your PC or not. If you do not connect.
And if there are other problems can be solved by yourself, so be sure to take a little help from the Internet. Put the correct model number with its brand name and check with their service or even the cab number to call for consumers to aid verbal. This way, you can find solutions to many problems.
But in the case, if this is not your cup of tea, then good for getting help from a local supplier and get your electronic speaker repaired. And still not interested in saving money on it then the only way is to contact someone who knows you well and is in the mail. This person can resolve the problem with computer speakers.
Here are some of the most effective ways to solve your computer speakers, which not only shows you how to find an exact problem with your computer speakers, but also guide you through the solutions to these problems. But one thing you must remember that if not followed this advice in an orderly manner, you can earn up land with more problems with your speaker system. Then do as suggested and find the best results without losing much of your money on it.
Computers & Internet Logo
where I can buy another set of this type of speakers? Please send all info. Thank you.
I dont think you will be able to purchase the A215 speakers as they are End Of Life and DELL nomore ships these speakers.Go to the below link and order the speakers according to your requirement.
http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6178&cs=04&l=en&s=bsd&~ck=anav&nf=34533~0~325895&navla=34533~0~325895
Jan 03, 2011 | Dell A215 Computer Speakers
My dog ate the cord for the volume control. How can I buy a new one?
type in Logitech Z-2300 speakers volume cord that may help or check from where you bought them
Jan 29, 2010 | Logitech Z-2300 Computer Speakers
The switch on this quit working. Can I get buy a
Good day sir, hi, yes you can buy the replacement for that switch, take a picture of that switch using any camera phone, or if the speaker is not that heavy, bring it to your local electronics shop.
Nov 04, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
164 people viewed this tip
David Payne
David Payne
