Tip & How-To about Video Game Consoles & Games
How to connect Nintendo DS/DSi/DsiXL to the internet
Nintendo Dsi/DS/Ds XL connects to the internet using wireless connection. You need to know the settings of your router. I've listed below the steps on how you will access the router and to obtain the information needed for you to be connected.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and theNetwork Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection.
Video Game Consoles & Games Logo
Unable to connect my new nintendo DXi XL to wireless internet
Welcome to Fixya.
Sep 10, 2011 | Nintendo Dsi XL Midnight Blue - Utlsbka
how to get nintendo wifi
Aug 05, 2011 | Nintendo Dsi XL Midnight Blue - Utlsbka
how do you get the internet working on the dsi xl
Feb 13, 2011 | Nintendo Dsi XL Midnight Blue - Utlsbka
I can't find a compaible access point on my ds I'm playing animal crossing wild world I try to connect but it says Error code: 51099
Error Code: 51099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
Jun 05, 2010 | Nintendo DS Lite
my nintando DS gets error code #51099 everytime I try to connect to the internet on pokemon soul silver. Do you have any ideas?
Apr 20, 2010 | Nintendo DS Lite Console
2,058 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
