Tip & How-To about Computers & Internet
Fix a Sluggish Computer
The computers work fine when they are new. But over time the increase in use, it reduces the overall performance of your computer. I wonder what could be the cause of poor computer performance. Well, there are several reasons why your computer may slow down. Applications may be a virus, or it may be a register has been damaged. Go through this article and find out how the speed of computers can be added.
There are some common reasons why computers can slow down. Over time, junk stored on your computer, which ultimately reduces the performance of your PC. If these reactions are smoothly removed at a periodic interval, they will never come across problems like speed to the computer. To make your computer running at its best, you can hear a provider of computer support services remotely. Many companies offer computer repair technical support for PC users at a price easily.
You can also perform some simple tasks on their own in this regard. If done correctly, you can not face problems like a PC slowdown. You must first clean junk application. Windows stores large amounts of data where a substantial part is useless and corrupt. You need to get rid of computer waste in order to increase computer performance. Whether you have a laptop or desktop computer, perform this task on a regular basis.
Take care of your Windows registry is also another important part of fixing slow computer problem. The registry is a very important part of the Windows operating system because it contains information on all personal computer software programs. Corruption in the Windows registry can cause errors and crashes. For faster performance computer, you must delete the invalid registry periodically. You can find many registry cleaner software on the market. Choose one of these programs and clean your registry. Cleaning the Windows registry can also be performed manually. But most users do not have sufficient expertise and talent to accomplish this task.
Defragmenting a hard disk is one of the most important ways to improve computer performance significantly. Disk Defragmenter has a utility for the Windows operating system and you can easily use. Select the disk and defrag is faster.
Computers & Internet Logo
What's a good set of race heads for a 98 yzf r1
Not entirely sure of your question. Are you meaning the cylinder heads? You can do some things to the heads, porting, polishing, shaving etc. to increase performance and efficiency. However, you don't generally replace the heads themselves with anything other than what was designed for that particular block. If you are looking for ways to increase the performance of your R1 there are many things that offer more bang for the buck. First would be some light weight wheels, magnesium wheels will reduce overall weight and increase acceleration etc. Cams, power commander ECU, after market exhaust (drops overall weight while generally increasing HP), SS brake lines, Galfer-like pads, racing battery (or none at all, less weight) racing bodywork, K&N air filters, the list goes on and on. Are you going to be racing this bike full time or just track days? There is a lot to be said for reliability. Unless you've been racing for several years, ie lots of experience all ready, there are a ton of things to learn as a rider to going faster than just more hp on the bike. There are racing schools available that can make you a much faster rider on the same bike. If you have unlimited funds for the racing effort than consider buying a Graves built superbike motor and just bolt it in. If you are on a budget, consider losing body weight (approximately every 7 pounds = 1 HP), reducing weight of the bike (aftermarket wheels, exhaust, rotors, bodywork, etc. etc.). Hope this helps.
Aug 16, 2014 | Motorcycles
how to increase my gaming graphics of aspire L310 desktop
Your computer uses the Integrated IntelĀ® Graphics Media Accelerator 3000, which is built into your motherboard. Unfortunately, there are no additional drivers for your computer so performance can not be upgraded, in that sense.
What you can do though is increase the screen resolution (on the desktop and in game settings). This should allow for a sharper, clearer image and a better overall gaming experience
Jun 14, 2011 | Acer Aspire L310 Desktop
I have lg dvd r/w in my P3 System but I am facing three problems. 1) Dvd is not playing the movies normally, that is movie is coming in a breaking manner. 2) whenever I am trying to do something to that movie it is hanging. 3) when I put the dvd it is not showing any files or folders in it. It is showing files or folder if its a cd. when comes to dvd this is problem. Please help me........
It sounds to me like your computer system is not up to the task of watching DVD movies. It is a P3 and as your computer plays movies in a breaking manner it shows that the graphics performance is very low. In fact the overall system performance in very low.
The solution is to save up for a faster PC that you can afford, It doesn't need to be new it can be second hand, it must just be able to do what you require it to do.
A cheaper solution is to find and install a compatable Graphics Card for your computer, this will increase the overall performance of your computer.
I am deeply sorry for this sad information.
Wishing you all the best!
damnor01
Jan 04, 2011 | Acer Computers & Internet
I increased memory from 512 to 768 on Dell desktop with 2.4 celeron but did'nt seem to increase speed.what is the problem? Ray.
That minimal amount of increase is not going to be a very noticeable increase also the processor or a faster RPM hard drive is more for the speed. you can go to the system properties in control panel and then the advanced tab and then the settings tab on performance then to the Advanced Tab then to change tab in virtual memory then to custom size make the initial setting 1.5 times the amount of memory installed in your case 768 x 1.5 = 1152
on the max 3 x the amount of memory again, in you case 768
768 x 3 = 2304
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
Does the MX 310 work with Vista
Looks like you will need to download a driver.
You'll need to know if you have Regular Vista or Vista 64-bit.
Here's how you can tell:
64-bit versions of Windows Vista are for computer users who have high-performance needs and are typically running a computer with 4 GB or more of Random Access Memory (RAM). The terms "32-bit" and "64-bit" refer to the way a computer's processor handles information. The 32-bit versions of the Windows operating system can only use up to 3 GB of memory.
The 64-bit versions of Windows can use more memory and help reduce time swapping processes in and out of memory by storing more of those processes in RAM rather than on the hard disk. This, in turn, can increase overall system and application performance, especially with applications optimized for 64-bit. For more details about 32-bit and 64-bit, see the Windows Help and How-to FAQ.
To find out what version of Windows Vista is installed on your computer:
  1. Click Start start.gif, click Control Panel, click System and Maintenance, and then click System.
  2. Under System, view the System type.
If you're running Windows XP:
  1. Click Start, click Control Panel, and then double-click System.
  2. On the General tab, view the System type.
Now you know your system type and can download the correct driver from this page:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603#DownloadDetailAct
Let me know if that works for you. Be sure to follow all the directions.
Mar 26, 2009 | Canon PIXMA MX310 All-In-One Printer
212 people viewed this tip
David Payne
David Payne
