Tip & How-To about Computers & Internet
Setup BIOS Repair Tips
BIOS is the Basic Input Output System, which serves as an introduction to the operating system installed on your computer. With BIOS of your computer's operating system starts to communicate with hardware devices of the computer. BIOS can be found in a small chip that is integrated into the motherboard of your computer and provides important information while the computer is booting. For one reason or another user need to enter the BIOS and computer repair services experts sometimes explains how to enter the BIOS setup.
A misconception is widespread among ordinary people. Most of them believe that through the BIOS setup of the system configuration can be changed if the reality is different. BIOS is a ROM, and since it can never provide the data to change. Then, all data and settings are stored in the memory configuration. Now, the computer support experts like the idea of letting you know how to let go into the BIOS setup.
There is no safe way to enter BIO created. However, computer technician suggests you can use the F1 to F2, F10 or Del to enter Setup. In fact, the way you enter it varies by manufacturer. When the memory count, press a button when you hear the beep. You must ensure that you read and follow the startup screen. If you miss something you might need to restart your computer. When you enter the area you can use certain keys to perform navigation. As you can press 'Enter' to select a menu and press the arrow keys to navigate the various options. You can press Esc to return to the previous menu and press the Page Up and Page Down buttons to modify an existing device. Then make the changes you intend to do that you must save the settings before exiting the game, suggests expert computer repair.
Computers & Internet Logo
instructions
There are no such thing as "Instructions" for a desktop computer apart of the basic input output.system (BIOS)
The moment your computer start's up, the operating system takes control of your computer and boots up until startup has finished.
If you don't have any operating system istalled, you should install one.
If you don't understand what I'm talking about, look for a PERSONAL HELP
Sep 04, 2015 | Computers & Internet
download drivers
Ummm, no such thing.......
Driver: Small piece of software that allows the Operating System to communicate with a device
BIOS: Basic Input/Output System program
When you press the Power On button, the plastic assembly of the Power On button; presses against the Power On switch located inside it.
The Soft Power On circuit is activated.
This 'excites' the Power Supply, and turns it on.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the CPU (Processor) on; and hands the computer over to the Operating System.
To perform ANYTHING with BIOS in the respect you are stating, you would be performing a BIOS update.
The BIOS program in modern personal computers, no longer uses BIOS drivers.
"Older types of OS would use the BIOS to access hardware on the computer, but most new versions now access hardware directly through drivers built into the OS."
(OS = Operating System)
http://www.wisegeek.com/what-are-bios-drivers.htm
(Sometimes people just have to see another tech state this, just to make them feel comfortable about it, IMHO)
Know this;
IF, the power goes out when you are performing a BIOS update, your computer turns into an expensive doorstop.
IF, the BIOS update is not compatible with your computer, your computer turns into an expensive doorstop.
IF, you do NOT save the original BIOS program, and the above happens, your computer turns into an expensive doorstop.
Now,..........why is it you wish to fool with your BIOS program?
Post back in a Comment. Or click on Reply at end of this solution, and post.
Regards,
joecoolvette
May 14, 2013 | ASUS Eee Computers & Internet
how can i get to command prompt in dos through bios?
Sorry but basically you cant access command propmt through the bios. The command prompt is part of the operating system of the pc, either as DOS (disk operating system) or part of windows.
The BIOS (Basic Input output system) which is on a rom(read only memory) chip on the mother board, and initiates post(power on self test) when the computer starts, without the bios the computer would not boot up at all. To access the command prompt you must have a operating system installed, ie Windows. hope this helps.
Sep 23, 2010 | Computers & Internet
what is bios?what bios is cmos
BIOS =Basic Imput Output System. CMOS is the onboard chip that stores the info for the BIOS.
CMOS chips pass information to the BIOS (Basic Input/Output System) when the computer is turned on (called bootup). CMOS stores information such as boot order (the order the computer looks for information, such as A drive first, C drive second, and so on), real-time system clock, calendar settings, hardware passwords, hard drive configuration settings, and the installed memory (RAM). Essentially the CMOS chip stores data for the BIOS so that a computer can boot up properly.
Aug 28, 2010 | Computers & Internet
BIOS DEFINATION
Basic Input Output Service....It is the chip on motherboard ,in which all instruction written for identifying the hardware
Dec 03, 2008 | Computers & Internet
310 people viewed this tip
David Payne
David Payne
