Tip & How-To about Computers & Internet
How to Enable Touchpad in a Laptop
TouchPad is disabled sometimes for no apparent reasons.To reactivate, first you restart your computer. If no change, you can activate it by going to the mouse properties. In some laptops, you can try pressing FN+F7.
If you are using Windows XP in your computer, you can do the following:
1. Go to control panel>mouse>device settings
2. Click enable
3. Click Apply
4. Click OK
NOTE: If the troubleshooting above does not work. Click on reset devices>Apply>OK. Then restart the computer.
*****If your computer runs in Windows 7/VISTA, then follow the following steps.
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Make sure that the mouse in the list is enabled.
4. If disabled Click Enable device.
5. Click OK.
If the above troubleshooting does not make any changes. Update the driver of your touchpad. You can visit http://www.synaptics.com/ to get the drivers and software needed for your touchpad to work. Or, you can go to the website of your computer's manufacturer because they have the available updates and drivers which you can download and it will surely fix the problem.
Carloadrian
Computers & Internet Logo
want to disable touchpad on my HP Pavilion G7-1277dx
On laptops, sometimes the TouchPad can be disabled for no apparent reason. To reactivate it, first try restarting your PC. If that doesn't help try the following:
  • Go to Control Panel > Mouse > Settings
  • Click Enable (or Disable to disable)
  • On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, on an ACER machine, press FN + F7
  • You can click "Reset device" if neither of those solutions work
  • The official website provides synaptics drivers and software needed to run your TouchPad
On the latest laptops, there is a special button to enable/disable the TouchPad
Jan 12, 2013 | HP Pavilion G7-1277dx 17" Laptop Pc -...
I bought a new asus laptop 3 weeks ago, one of the reasons I chose it was the feature of disableing & enableing the mouse pad. (I'm 72 yrs, old & I have bad tremmer. Since I had a heartattack '95.) It worked well for me for about a week, then I had a soft ware problem they couldn't fix. They reprogrammed my ASUS to fix another problem, and since then When I press th FN-F9 buttons they don't set the disable feature any more. The Co. I bought it from is unwilling to reset it for me. (Kearney Computer Solutions; Kearney, Ne.
Disable / Enable the TouchPad Share « PreviousNext » Summary
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there's no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Windows Vista.
  • Go to Control Panel> Mouse> Settings tab of the device
  • Click (or to disable)
Notes:
  • On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
  • You can click Reset device if neither of those solutions will work.
  • The official website provides synaptics drivers and software needed to run your TouchPad.
  • On the latest laptops, there is a special button to Enable/Disable the Touchpad.
  • HOPE THIS HELPS
  • NORMAN
Aug 23, 2011 | Computers & Internet
touchpad on/off button problem
Thank you for posting your problem in fixya. My name is Carlo.
I understand that you have a problem with your touchpad button. TouchPad is disabled sometimes for no apparent reasons.To reactivate, first you restart your computer. If no change, you can activate it by going to the mouse properties. In some laptops, you can try pressing FN+F7.
However, if the above troubleshooting does not fix the problem. I suggest you click on the link below so that you will be directed to a guide a prepared on how to fix this kind of problem.
http://www.fixya.com/support/r8113144-enable_touchpad_in_laptop
I hope this helps.
Thank you for using fixya.
Carlo
Feb 03, 2011 | HP Compaq Presario CQ60615DX Notebook
lock fingerpad hp
Thank you for using fixya. I am glad to help you.
TouchPad is disabled sometimes for no apparent reasons.To reactivate press FN+F7.
If it does not change anything, restart the computer and check if it works fine. Restarting the computer will refresh everything in the computer and thus fix the problem with the touchpad. However, if for some reasons the restart won't change a thing then you better click the link so that you will be directed to the full troubleshooting that I made here in fixya. Click the link below:
I hope this helps. Thank you for using fixya.
Cheers!
carloadrian
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Feb 03, 2011 | Computers & Internet
I've disabled my touchpad and can't use my laptop, I've tried Fn+F7
TouchPad is disabled sometimes for no apparent reasons. I understand that you even tried pressing the FN+F7 with no go at all. To reactivate, first you restart your computer. If no change, you can activate it by going to the mouse properties.
2. Click enable
3. Click Apply
4. Click OK
*****If your computer runs in Windows 7, then follow the following steps.
5. Click OK.
If the above troubleshooting does not make any changes. Update the driver of your touchpad. You can visit http://www.synaptics.com/ to get the drivers and software needed for your touchpad to work. Or, you can go to the website of your computer's manufacturer because they the available updates and drivers which you can download and it will surely fix the problem.
It could have been very helpful if you provided fixya with the operating system and the model of your computer enable for us to provide you with a detailed location of the driver of your touchpad if there's a need for you to download it.
Thank you for using fixya. Just let me know if you need my help. Just leave a message in this post.
Carloadrian
Feb 02, 2011 | Computers & Internet
3,111 people viewed this tip
David Payne
David Payne
