Tip & How-To about Computers & Internet
Tips to Make Your Notebook Computer Run Better
Many times people complain that the dose does not run that laptop is used. It very much depends on how and where to use it as if it still works as it should. Here are five tips to keep a laptop running well.
Store in a flat, level surface so that air can circulate through the equipment to keep it fresh. If air can not pass through the computer and motherboard and the heat warms the system and cause more damage. In some cases, the computer shuts down and restarts until cool. In this case there may be permanent damage, but the computer still can work, but you may notice the water is warm and mostly slower than normal.
Depending on the configuration of the laptop, you may notice the jerky movement when viewing items on the screen. As watching videos, music, or simply opening the table. This can be a problem with graphics capabilities. If you have set the screen saver and desktop wallpaper of the image you need to change them. September both "None." Now, turn off the computer, wait 15 seconds and then restart it. You should see an improvement now.
Some programs are memory hogs. They take all the memory your computer has, and then the system uses your hard drive for virtual memory. This means that the system will take some of your disk space and use it as it uses your memory chips. This works for most applications and normally does not affect the operation of your computer. But if you notice after the launch of a program and then use it for a short period of time the computer starts to slow then you need to do a memory up grade. You may need to consult a computer expert for this.
Computers & Internet Logo
no beep and no screen my f
this a problem with the POST, you must go to the shop repair computer.
However RUN the software diagnostic coming with the computer restart and HOLD the key CTRL +f11 or f12 and use it
God bless you
Jun 04, 2013 | Fujitsu Siemens FUJ:CA01007-0930 Laptop AC...
wife complains that clothes are not drying like they used to she has to run second time. dryer feels warm, blows out vent, vent is all clean and clear
Depending on the age... your heating element maybe on its way out, they are not terribly expensive or difficult to replace and can be done by a DIY person. Hint: make sure it is electrically completely disconnected and that all of the lint is removed around the impeller (which is in the same area you will be working), you will be surprised how much lint can collect, too much can make a fire hazard.
Feb 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Blue screen & A message pop-up on my ToshibaSatellite A105-S4011:
try removing some unwanted programs. run disk cleanup, then defrag
Apr 04, 2010 | Toshiba Satellite A105-S4011 Notebook
Playstation 2 USB + HDD
actually the USB port on the PS2 is for game paraphernalias like ps2 keyboard or ps2 webcam and other accesories and it also depends on the game
if you're trying to play a game saved on an HDD using the USB, it really won't work
Jun 17, 2008 | Sony PlayStation 2 (PS2) Console
167 people viewed this tip
David Payne
David Payne
