Tip & How-To about Microsoft Windows XP Home Edition
Windows XP: How to release and renew IP addresses
IP addresses can either be assigned manually or automatically. When they are assigned automatically, a DHCP (Dynamic Host Configuration Protocol) server hands them out and determines which computer or other device gets which address. This process usually flows smoothly, but there are times when you may need to release or renew an IP address even when using DHCP.
There are several ways to release and renew IP addresses in Windows XP. Each procedure is described below.
From the system notification tray:
1. Right click on the network connection icon in the system notification tray.
2. Select Repair. Windows will automatically release the current IP address, reset the network connection, and request an IP address from the DHCP server. (The new IP address that gets assigned may be a different one from before, or it may be the same one.)
From the Start menu:
1. Click the Start button.
2. Right click on My Network Places.
3. Select Properties.
4. Right click on the network connection that is currently in use.
5. Select Repair. (If you choose a network connection that is not in use, Repair will be grayed out.)
For either of the above methods, you can release and renew your IP address manually by clicking Disable instead of Repair, and then right-clicking and choosing Enable.
From the command prompt:
2. Click Run.
3. Type "cmd" and press [Enter].
4. At the command line, type "ipconfig /release" and press [Enter].
5. Type "ipconfig /renew" and press [Enter].
6. Type "exit" and press [Enter].
Microsoft Windows XP Home Edition Logo
find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
How do I change my WD5000G032-001 external hard drive's IP address?
Very few external disk-drives _have_ an IP-address (the Apple Time-Machine is the exception). For those drives that do,
they obtain their IP-address automatically, by sending a 'request' out through their network-connection. A DHCP ('Dynamic Host Configuration Protocol') server on the network sends an IP-address to it. Most 'home' routers (wired or wireless) include the DHCP-server functionality.
So, the only way to change the IP-address is to configure the DHCP-server to always assign the desired IP-address whenever that specific device sends a 'request' for an IP-address.
Oct 06, 2010 | Western Digital 500GB My Book World...
how do i get my router to not give out IP addresses
Turn off the "DHCP Service".
That would be "Dynamic Host Configuration Protocol", and it's the service that assigns IP addresses automatically.
If you need "DHCP" to connect yourself, you could always turn off your "ssid broadcast".
That way, nobody (including you) will see your router while scanning, wardriving, etc.
Of course, you will know it's there and what "ssid"
you gave it, so you'll be able to connect just by using the right ssid.
Nov 27, 2008 | Computers & Internet
Wireless internet hookup
What seems to be the problem of your wireless internet?
Mar 27, 2008 | Computers & Internet
What is BOOTP/DHCP?
BOOTP stands for Bootstrap Protocol. DHCP stands for Dynamic Host Configuration Protocol. Both are mechanisms to dynamically assign an IP address for a TCP/IP client by the server. In this case, the Prestige 310 Internet Access Sharing Router is a BOOTP/DHCP server. Win95 and WinNT clients use DHCP to request an internal IP address, while WFW and WinSock clients use BOOTP. TCP/IP clients may specify their own IP or utilize BOOTP/DHCP to request an IP address.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
1,214 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
