Tip & How-To about Cell Phones
Start up Blackberry Quickly
To start up your blackberry quickly just plug in the blackberry charger as if you were charging the phone and press the on button
Cell Phones Logo
just bought a new Blackberry storm 9530 and it is not getting charged. Please help
Usually for brand new phones, the battery needs to be charged for two hours. But if you found out after it's been a while and it's not charging, make sure the battery is inserted correctly. If it's and the led is not on or no charge indicator, do the following, take out the battery, unplug the charger from the phone, press and hold the power button for five seconds. This drains out the battery. Now put the battery back in, plug the charger into the phone and let charge. Don't worry if it doesn't recognize it immediately. I hope this helps
Mar 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
blackberry 9530 touch screen does not function
If the problem occurs while charging with the wall charger then try changing the wall charger.
Jun 08, 2010 | RIM BlackBerry Storm 9530 Smartphone
blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
black berry that wont turn on
Remove the back of the phone. Pop out the battery. let it sit for about 10 minutes. Replace the Battery & the back cover of the phone. If the phone starts up, then let it start and immediately plug in the charger and let it charge for 1/2 hour before you touch it again.
If the phone does not start up then do not try to start it just immediately plug in the charger and let it charge for 1/2 hour before you touch it again.
It works for my Blackberry Curve 8310...
Nov 25, 2008 | AT&T Blackberry Curve 8300 Smartphone
108 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
