Tip & How-To about HP Deskjet D2360 InkJet Printer
How to uninstall and reinstall HP Deskjet D2360 Printer
I think you need to uninstall and reinstall your HP printer drivers.
to do this follow these steps:
1.
Select Start , Settings , and Control Panel .
2.
Double-click the Add/Remove Programs utility.
3.
Select the HP Deskjet D2360 Printer and click Add/Remove
4. Restart your computer
To reinstall HP Deskjet D2360 Printer
Make sure that the printer is properly set up, turned on, and ready to print.
Check that all cables are firmly connected.
For Windows XP
NOTE: You must have administrator privileges in Windows XP Professional to install a printer driver.
1.
Close any unnecessary programs that are running on the computer using the steps below.
1.
Right-click any program appearing on the Taskbar next to the Start button and choose Close .
2.
Repeat step a. until all the programs appearing on the Taskbar are closed.
2.
Click Start , Printers and Faxes , and then Add a Printer .
3.
Follow the instructions on the screen to finish the installation.
For Windows XP Home Version
1.
1.
2.
2.
Click Start , Control Panel , Printers and Other Hardware , Printers and Faxes , and then Add a Printer .
3.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks,
LETMEFIXIT
HP Deskjet D2360 InkJet Printer Logo
unable to reduce brightness windows7 ultimate 32bit
Hi nehamadullah,
Here are a few methods which you can follow to resolve the issue:
Method 1:
I would suggest you to uninstall and reinstall the display adapter drivers and check:
Step 1:
Follow the steps provided below to uninstall the graphical drivers.
a.Press windows key + R and type indevmgmt.mscand clickenter.
b. Expand'display adapters"and right-click on'drivers Deviceand select 'uninstall'.
Step 2:
b. Expand'display adapters"and right-click on'drivers Deviceand select 'update drivers'.
In Case You Still Having Problem Then Follow Us For On :
HP Printer Support
Jul 26, 2012 | HEWLETT-PACKARD Hewlett Packard (HEWELTT...
my computer stopped recognizing my hp psc1350 and it won't print
If this is not hardware problem then most probably the driver is corrupt.
First uninstall the printer completely using the procedure below (taken from HP website).
Uninstalling the software
Use the following steps to uninstall the software:
1.Disconnect the USB or parallel cable from the all-in-one.
2.Click Start , click Programs (click All Programs in Windows XP), click HP , select the all-in-one product folder, and then click Uninstall . Follow the directions that appear.
The basic device drivers have been removed after completing this step. If you were having problems with connectivity or the basic print or scan drivers, you may reconnect the all-in-one at this point to reinstall it. If the problem is not corrected or if you had other problems, continue to the next step.
3.Open the Windows Control Panel by following these steps:
* Windows 98, Me and 2000: Click Start , click Settings , and then click Control Panel .
* Windows XP: Click Start and then click Control Panel .
4.Click Add/Remove software (click Add or Remove Software in Windows XP).
5.In the list of installed programs, locate and select HP Photo and Imaging 3.0 or HP Image Zone , and then click Remove . Restart the computer after uninstalling if prompted.
6.In the list of installed programs, locate and select HP Software Update , and then click Remove .
7.In the list of installed programs, locate and select Memories Disk Creator 2.0 , and then click Remove .
Reinstall using updated drivers from the link (for XP)
ftp://ftp.hp.com/pub/softlib/software4/COL8901/mp-23606-2/gc_w01_ENU.exe
If windows vista then it will install the drivers automatically on connecting the printer
Jul 28, 2009 | HP Office Equipment & Supplies
my new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
When I hit scan it says "no scan options"
Hi just follow the below steps and the problem will be resolved.
Solution:
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
Dec 28, 2008 | HP Officejet J5780 All-In-One InkJet...
printing problem
hi,
You need to reinstall the printer driver.
First check which operating system is used with your product? After that download the software from Download  Full Feature Software and Drivers.
How to Uninstall the printer Software :-
Follow the steps below to remove the hp LaserJet 1020 series software from the computer:
  1. Disconnect the USB cable from the computer.
  2. For the Windows Desktop, click Start , click Programs or All Programs , and then clickhp LaserJet xxxx series .
  3. Click Uninstall hp LaserJet xxxx series .
  4. Follow the messages on the screen to remove the software.
  5. Reboot the computer when instructed.
OR
2. For the Windows Desktop, click Start , click Crontrol panel, select add\remove(XP) or program future (VISTA).
 After restart install the printer driver and follow the screen instructed.
Sep 02, 2008 | HP LaserJet 1022 Printer
2,742 people viewed this tip
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
