Tip & How-To about HP PSC 1610 All-In-One InkJet Printer
HP Scanjet 4200C Won't Work With Windows XP
Turn off the scanner or disconnect it.
Select your HP Scanjet type from the selection.
Select "Microsoft Windows XP" from the list of operating systems.
Click the Driver "Download" and, if you want the additional software, "HP System Diagnostics Utility."
Double click the downloaded driver file to launch setup. During the setup process you will be prompted to connect your scanner and turn it on. Once finished you will have correctly set up the scanner for Windows XP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks,
LETMEFIXIT
HP PSC 1610 All-In-One InkJet Printer Logo
Hp scanjet 3690 is not support by Microsoft Windows 7
Hi, 1)Go to the below link. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=298545&lang=en&cc=in&prodTypeId=15179&prodSeriesId=298543&taskId=135
2)select the operating system of your choice as Microsoft Windows seven 3)Download the driver for windows seven 4)good luck
Nov 27, 2010 | HP ScanJet 3690 Flatbed Scanner
hi this is from chennai... i have hp scanjet g3110 .. it was worked good till before october.. now the software didnt open..i had installed the software many times.. no response... i had installed updated software also.. i dont know that what should i do for this problem..so plas help .. my id is ganblack@gmail.com.... when i was open the software... it didnt open.. my work have holled on this problem..pls i need some help
first before installing any software turn off you anti-virus program.
next uninstall the scanners software completly before installing a new copy to do this just goto control panel select program and features. then select the hp program for the scanner and double click on uninstall.
then do the following:
1) disconect the scanner from the computer.
2) insert the disk that came with the scanner.
3) attach scanner and allow it to find new driver.
4) scanner should work.
if this does not help then email me at rafurmanekjr@hotmail.com and i will log into microsoft messenger, and try to assist you live ok
Rob
Nov 25, 2010 | HP Scanjet G3110 Flatbed Scanner
how to set up and use
What is your computer's operating system? » Microsoft Windows Vista » Microsoft Windows Vista (64-bit) » Microsoft Windows XP » Microsoft Windows 2000 » Microsoft Windows ME » Microsoft Windows 98 » Microsoft Windows 95 » Microsoft Windows NT 4.0
Oct 06, 2007 | HP ScanJet 2200C Flatbed Scanner
1,933 people viewed this tip
Seeker5211
Seeker5211
