Tip & How-To about Office Equipment & Supplies
Tips to Choose an A3 Printer
When it comes to printing, there is a wide range of printers available. Primary A3 printers to print pages that are double the normal A4 page. A3 pages is useful when you want to print a large amount of data or a poster in an organization. When you want to make a difference with your A3pages, you should have the right printers A3. While choosing your A3 printer, there are some things to keep track of how you choose.
There are several types available in the market. You need to know what you want in your A3 printer that you will use. When you have a clear idea of how to choose a printer A3 becomes really easy for you. A3 printer comes with many features such as A3 printer scanner added, direct printing from USB flash drives, using the A3 printer and a fax with A4 printer as a copier and even a Wi-Fi and network interface.
With so many options available, you need to know how to choose an A3 printer to make a wise investment. Even though prices have been reduced, they can be very pricy. Instead of buying an A3 printer that has all the integrated features, you can choose only those needs that you need. This will save lots of money.
A3 printers are easy to maintain, you must be prepared to do regular checks. If you do not want your printer needs servicing often, so please select the top sustainable. They require frequent maintenance or filling of cartridges, as they will last far beyond the normal flow of printers.
How to choose the printer is a very important aspect, especially when there are so many options available. Each printer has its advantages. You may have the same characteristics of the second A3 printer, but it could fit right, if you want, within your budget and needs. In addition, you must decide whether it should be for commercial purposes or common house hold. It is A3 printers with different capabilities, such as the number of pages per minute, so in the light where you need a printer, you should opt for an A3 printer wisely and make best use of it
Printer problem
From the Printers & Faxes window, check in the i9950 Printing Preferences, Page Setup tab, for the following settings:
Page Size and Printer Paper Size are both set for the same size (both A4 or both A3).
Printing Type is set for Normal-size Printing
The graphic on the left should now show A4 (or A3) and Normal-size Printing in the legend.
Once that is set, verify from the application you're printing from that these settings are not being changed by the application (Preferences button in the print dialog box).
Jun 16, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Hi, I am using ms word 2007 and need an a3 sheet format. Its not in the page set up drop down menu and the only solution I have is to customise my page size. Even doing this however, and increasing my margin size appropriately, the print preview only shows the section of the paper which would cover an a4 page. Is there another solution? Thanks, Paul
The print sizes available are dependent on the printers installed.
If you don't have an a3 printer installed on your computer, there won't be a A3 option in word.
if you install a standard pdf printer like cutePDF(simulates printer, but instead of printing document on paper, it generates an adobe pdf-file from the document) the option should become available in your dropdown.
Apr 04, 2008 | Computers & Internet
A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Feb 14, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
251 people viewed this tip
k24674
jasbo
jasbo
