Tip & How-To about Everex VA1500V-R Notebook PC
Trick Help Your PC Perform Like New Again
A computer can be compared to a piano. piano keys must be refined from time to time for a good sound. Personal computers, however, must be well maintained to keep it running like new. To improve the performance of a PC, you should start by cleaning the Windows registry. These are the steps on how to improve the performance of your PC.
First, scan the Windows registry using a registry cleaner. Just be careful not to use software that is loaded with viruses and other hacking devices. Use only software that is already proven and have a good reputation. You can easily find them by looking at other online tests.
Another tip for choosing a registry cleaner is to choose one that has the ability to reverse its actions. Some cleaners are sensitive to specific files and delete the key features of your computer. When this occurs, you must have a back up or you may have to redo the registry cleaning to recover deleted data.
When cleaning the Windows registry is complete, scan and error correction is the next step in this process. To help your computer run like new, just clean up the registry, but also to remove the virus as well. virus removal can be done to find the right anti-virus program. It 's easier to remove the virus if the software is already installed on your computer, but otherwise you can still find online programs to use, that can help.
Everex VA1500V-R Notebook PC Logo
I have a M. Schulz Co. piano from Chicago. It has the date that M. Schulz was establish 1869 inside, along with the serial number 76271. Any idea how old it may be?
Good thinking :>) Also remove the middle C key complete and see if there is writing on it.
M. SCHULZ & CO.
Pianos, player-pianos. Grand and Reproducing Pianos known throughout the piano world as instruments of the highest class. The M. Schultz piano of the best known, most highly organized, reputable and extensive piano manufacturing concerns in the country. Technically, the instruments made by this concern and note for scientific correctness of scale, highest grade of workmanship, and extreme care in choice of only the finest in material, backed up by long experience. The tone quality of M. Schulz pianos is the strong point of them, possessing a roundness, purity and mellow singing beauty all its own. This company is also distinguished for turning out case work of true artistic excellence, with a purity of design and fineness of finish which are in every way distinguished. Added refinements in case designs of special period art models are features of M. Schulz Co. production. Aria Divina Reproducing pianos are a standard with dealers everywhere.
1907 - 3500 1913 - 80000 1919 - 140000 1925 - 190000
1911 - 62000 1917 - 120000 1923 - 170000 1929 - 226000
1912 - 71000 1918 - 130000 1924 - 180000 1930 - 230000
Feb 18, 2016 | Music
At times during a performance the organ sounds drops significantly compared to the ensemble sounds, what could be the problem?
Has it always done that? It could be it just doesn't have enough power to play organ at full volume along side the ensemble.
May 25, 2015 | Roland VR-700 V-Combo 76 Key Stage Piano
I want to plug my keyboard into my USB port
I just found the same program with the same cables. I am going to try a usb to midi cable made by m-audio only because I have it hooked up right now to laptop running xp and the old version of Mircacle Piano which is the best by far and it works great. It is an M-Audio usb to midi cable called the UNO or something like that. its the one for 39 bucks very simple. It should work as long as your computer is running windows OS thats compatable or try running in 95 mode. Also some of these programs recognize processor speed and dont work on the newer systems. Good luck with it. have you ever used seen this software before? Ever see Miracle Piano? wondering how they compare.
Apr 18, 2009 | Midisoft Play Piano 2.0 Full Version for...
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
1,299 people viewed this tip
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
