Tip & How-To about Lands Phones
How to identify your individual phone number, cell or home
Ever wondered how to make sure that your home phone, or even your cell phone has the correct number? Have your callers been unable to reach you, but you don't understand why, your phone seems to be working!!
Do you want to do your own houshold phone wiring on that new second or third line you ordered?
Ever just needed to know the number of the phone line where your're at, and no one is there to tell you?
ITS EASY!!! AND IT WORKS ON CELLPHONES, TOO!!!
Just pick up on the line in question, and dial the following number...
1 - 800 - 444 - 4444
You will get a digitized voice that recites the number you are calling from
I N S E C O N D S !
... also works on payphones, too!
Lands Phones Logo
My phone was showing caller ID but last evening it only showed incoming call. How do I get my caller ID to work? IT is working on my cord phone?
Hi
I would advise you to go through the instructions in the manual again very carefully to make sure you set it correctly, and then test it using a known number.
Caller ID is not infallible and will not display a number if the caller uses "number withheld" or in many cases if it is an overseas call.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Lands Phones
need instruction how to call forward?
You can now divert important calls to another mobile phone or landline if you are unable to take a call in case: you miss a call, are busy, are out of reach or phone switched of.
Activate
  • Go to the 'Call Divert' menu on your mobile phone
  • Select 'Divert if out of reach' option
  • Select 'Activate', followed by to other number option
  • Enter the number in the to other number section
  • Your Call Divert service will now be selected
Deactivate To deactivate go to 'Call Divert' menu and select deactivate / cancel option.
Also:
To forward all calls:
  • to start, enter **21*number #
  • to stop, enter ##21#
To forward calls while you´re speaking to someone else:
  • to start, enter **67*number #
  • to stop, enter ##67#
To forward calls if you don´t answer the incoming caller within 30 seconds:
  • to start, enter **61*number #
  • to stop, enter ##61#
To forward calls if your cell phone is switched off or is out of reach
  • to start, enter **62*number #
  • to stop, enter ##62#
To cancel all preset conditions:
  • enter ##002#
Jul 23, 2011 | Cell Phones
UNABLE TO SEE CONTACT OF CALLER :-NUMBRS,NAMES
try a master reset hopefully that corrects the issue
Dec 10, 2007 | Sony Ericsson W550i Cellular Phone
'no number' missed calls
yes i have the same phone and repair tonnes too.
clear the numbers on the phone, not the sim. now restart the phone switch off take battery out and push the red power button. now replace the battery and switch on. copy all the sim numbers onto the phones memory and backup the numbers onto a computer (a mobile phone store will do this for $25 (ish) )
now clear the sims numbers. so now all your numbers are on the phone only. this will solve the incorrect numbers which the phone reads off the sim incorrectly.
also good idea to clear the calls incoming, outgoing, missed, received.. by deleting them, as the D500 sometimes gets these confused as they are stored in the same place and under the same file headings.
this should fix the problem. also it a good idea, if the phone or sim is old...   is to get a new sim.. just get the number and so on to be transfered across.
or.... (please backup pics, vids, numbers everything!!!) try:
*2767*3855#
or
*2767*2878#
or
*2767*3855#
good luck.
Oct 28, 2007 | Samsung SGH-D500 Cellular Phone
Display of callers number.
No, if the network funtion is ofline at that moment it will do so. nothing we can do.
Oct 16, 2007 | Samsung SGH-D500 Cellular Phone
933 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
