Home | All Products | iPhone 3G | Tips
IPhone 3G instructions - disassembly
merryAnn
By Master merryAnn
Rank: Master
Rating: 92%, 28 votes
posted on Jul 20, 2008
Very Helpful
Got this great instructions from - www.rapidrepair.com.
Tools required:
Small Phillips Screw Driver
Small Flathead or exacto razor
Safe Open Tool
Remove the sim tray, use the included sim card removal tool (or a paper clip if you've lost the tool.)
Holding your device on end you will notice two small screws on either side of the dock. These screws must be removed in order to open the case.
Insert a small thin tool between the chrome ring and front panel glass directly above one of the screw holes. You will need to exert a small amount of pressure to separate the display from the back panel.
Lift the panel up from the dock end being careful not to tear or break any ribbons connected near the other end.
Unplug ribbons 1 and 2 by lifting them from the main board. Under ribbon 2 you will need to find and unclip ribbon 3, then carefully remove the display assembly.
Remove the seven screws circled in red. Note: One screw is located under the DO NOT REMOVE sticker.
Unplug ribbon 4.
Lift the mother board out taking note of the camera which is still connected to the underside of the board. You will need to unplug the ribbon circled in red.
Place the mother board to the side.
Use the attached tab to pull up on the battery, there is a mild adhesive on the back side, so it will take a bit of force.
Remove the screw circled in red.
Carefully remove the camera.
Remove the nine screws circled in red.
Remove the headphone jack and attached flex cable.
Remove the speaker assembly which also contains the dock connector, antennae and home button as well.
Remove the 2 screws circled in red.
Place the ******** assembly to the side.
Remove the 2 screws circled in red. You will find 3 screws on the opposite side which must be removed as well.
Lift the LCD free from the front panel glass.
Pictured is every component inside the iPhone 3G.
You did it!
Was this helpful?
Yes
No
5 people thought this was helpful
Comment #1
posted on Feb 25, 2009
4nicks1
By Apprentice 4nicks1
Rank: Apprentice
Rating: 0%, 0 votes
  I used  the 3G guide from, ifixit.com. it list each of the components, from battery to logiboard,display,etc.Each page has 3 photos with text, click on the  photo, and you get a much larger photo and to your right. there's a  thumbnail menu..check it out. 4nicks.
Comment #2
posted on Jan 11, 2009
ubiman
By Wiz ubiman
Rank: Wiz
Rating: 82%, 111 votes
iPhone 3G? Not even close to the P1i!
Comment #3
posted on Jul 24, 2008
Jonchuck
By Apprentice Jonchuck
Rank: Apprentice
Rating: 90%, 4 votes
Wow! So is the purpose here to get to the battery. I know it is sealed and the story goes that you have to buy a battery replacement from Apple and of course, send it back to them. How can one get a battery other than from Apple?
Can you Help with these PDAs problems?
Apple iPhone 3G
iphone is disabled
Apple iPhone 3G
cannot get friends posts. Message says no recent posts on...
Apple iPhone 3G
My iphone got saturated in the washing machine. How do I...
Apple iPhone 3G
i got this iphone from a friend and he locked it before he...
Apple iPhone 3G
i cannot connect/turn on wi fi
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
